[petsc-users] About the initial guess for KSP method.
Tue Mar 17 10:17:15 CDT 2020
On Mon, Mar 16, 2020 at 4:32 PM Xiaodong Liu <xliu29 at ncsu.edu> wrote:
> Hi, all,
> I am testing KSPSetInitialGuessNonzero using the case
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex50.c.html
> This case is special. WIth zero initial guess, 1 iteration can deliver the
> exact solution. But when I tried true for KSPSetInitialGuessNonzero, it
> shows the same convergence history as false.
> Does the code  change KSPSetInitialGuessNonzero to false automatically?
For that flag to make any difference, you have to pass in a nonzero vector
to KSPSolve(). This example does not do that.
Were you doing that?
     Matt
> Take care.
> Thanks,
> Xiaodong Liu, PhD
> X: Computational Physics Division
> Los Alamos National Laboratory
> P.O. Box 1663,
> Los Alamos, NM 87544
> 505-709-0534
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200317/fb3b00ae/attachment.html>
