[petsc-users] --download-fblaslapack libraries cannot be used
Fande Kong fdkong.jd at gmail.com
Sat Mar 14 17:37:08 CDT 2020
OK. I finally got PETSc complied.
"-lgfortran" was required by fblaslapack
"-lmpifort" was required by mumps.
However, I had to manually add the same thing for hypre as well:
git diff
diff --git a/config/BuildSystem/config/packages/hypre.py
b/config/BuildSystem/config/packages/hypre.py
index 4d915c312f..f4300230a6 100644
--- a/config/BuildSystem/config/packages/hypre.py
+++ b/config/BuildSystem/config/packages/hypre.py
@@ -66,6 +66,7 @@ class Configure(config.package.GNUPackage):
     args.append('--with-lapack-lib=" "')
     args.append('--with-blas=no')
     args.append('--with-lapack=no')
+    args.append('LIBS="-lmpifort -lgfortran"')
     if self.openmp.found:
       args.append('--with-openmp')
       self.usesopenmp = 'yes'
Why hypre could not pick up LIBS options automatically?
Fande,
On Sat, Mar 14, 2020 at 2:49 PM Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Configure Options: --configModules=PETSc.Configure
> --optionsModule=config.compilerOptions --download-hypre=1
> --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1
> --download-metis=1 --download-ptscotch=1 --download-parmetis=1
> --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1
> --download-slepc=git://https://gitlab.com/slepc/slepc.git
> --download-slepc-commit= 59ff81b --with-mpi=1 --with-cxx-dialect=C++11
> --with-fortran-bindings=0 --with-sowing=0 CFLAGS=-march=nocona
> -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2
> -ffunction-sections -pipe -isystem
> /home/kongf/workhome/rod/miniconda3/include CXXFLAGS= LDFLAGS=-Wl,-O2
> -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now
> -Wl,--with-new-dtags=0 -Wl,--gc-sections
> -Wl,-rpath,/home/kongf/workhome/rod/miniconda3/lib
> -Wl,-rpath-link,/home/kongf/workhome/rod/miniconda3/lib
> -L/home/kongf/workhome/rod/miniconda3/lib
> AR=/home/kongf/workhome/rod/miniconda3/bin/x86_64-conda_cos6-linux-gnu-ar
> --with-mpi-dir=/home/kongf/workhome/rod/mpich LIBS=-lgfortran -lmpifort
> You are missing quotes with LIBS option - and likely the libraries in the
> wrong order.
> Suggest using:
> or
> 'LIBS=-lmpifort -lgfortran'
> Assuming you are invoking configure from shell.
> Satish
> On Sat, 14 Mar 2020, Satish Balay via petsc-users wrote:
> > to work around - you can try:
> > Satish
> > > Its the same location as before. For some reason configure is not
> saving the relevant logs.
> > > I don't understand saveLog() restoreLog() stuff. Matt, can you check
> on this?
> > > Satish
> > > On Sat, 14 Mar 2020, Fande Kong wrote:
> > > > The configuration crashed earlier than before with your changes.
> > > > Please see the attached log file when using your branch. The trouble
> lines
> > > > should be:
> > > >  "    asub=self.mangleFortranFunction("asub")
> > > >     cbody = "extern void "+asub+"(void);\nint main(int argc,char
> > > > **args)\n{\n  "+asub+"();\n  return 0;\n}\n";
> > > > Thanks,
> > > > Fande,
> > > > On Thu, Mar 12, 2020 at 7:06 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > I can't figure out what the stack in the attached configure.log.
> [likely
> > > > > some stuff isn't getting logged in it]
> > > > > Can you retry with branch 'balay/fix-checkFortranLibraries/maint'?
> > > > > Satish
> > > > > On Thu, 12 Mar 2020, Fande Kong wrote:
> > > > > > Thanks, Satish,
> > > > > > But still have the problem. Please see the attached log file.
> > > > > > Thanks,
> > > > > > Fande.
> > > > > > On Thu, Mar 12, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > > > Can you retry with the attached patch?
> > > > > > > BTW: Its best to use the latest patched version - i.e
> > > > > petsc-3.12.4.tar.gz
> > > > > > > Satish
> > > > > > > > This fixed the fblaslapack issue. Now have another issue
> about mumps.
> > > > > > > > Please see the log file attached.
> > > > > > > > Thanks,
> > > > > > > > Fande,
> > > > > > > > On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <
> > > > > wrote:
> > > > > > > > > For some reason - the fortran compiler libraries check
> worked fine
> > > > > > > without
> > > > > > > > > -lgfortran.
> > > > > > > > > But now - flbaslapack check is failing without it.
> > > > > > > > > To work arround - you can use option LIBS=-lgfortran
> > > > > > > > > Satish
> > > > > > > > > > Hi All,
> > > > > > > > > > I had an issue when configuring petsc on a linux
> machine. I have
> > > > > the
> > > > > > > > > > following error message:
> > > > > > > > > >      Compiling FBLASLAPACK; this may take several minutes
> > > > > > > > > >    TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > > > > > > > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see
> > > > > > > configure.log for
> > > > > > > > > > details):
> > > > > > > > > > The configuration log was attached.
> > > > > > > > > > Thanks,
> > > > > > > > > > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200314/1be1c2e5/attachment.html>
