[petsc-users] --download-fblaslapack libraries cannot be used
Sat Mar 14 15:48:42 CDT 2020
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-hypre=1 --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1 --download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1 --download-slepc=git://https://gitlab.com/slepc/slepc.git --download-slepc-commit= 59ff81b --with-mpi=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0 CFLAGS=-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /home/kongf/workhome/rod/miniconda3/include CXXFLAGS= LDFLAGS=-Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--with-new-dtags=0 -Wl,--gc-sections -Wl,-rpath,/home/kongf/workhome/rod/miniconda3/lib -Wl,-rpath-link,/home/kongf/workhome/rod/miniconda3/lib -L/home/kongf/workhome/rod/miniconda3/lib AR=/home/kongf/workhome/rod/miniconda3/bin/x86_64-conda_cos6-linux-gnu-ar --with-mpi-dir=/home/kongf/workhome/rod/mpich LIBS=-lgfortran -lmpifort
You are missing quotes with LIBS option - and likely the libraries in the wrong order.
Suggest using:
LIBS="-lmpifort -lgfortran"
or
'LIBS=-lmpifort -lgfortran'
Assuming you are invoking configure from shell.
Satish
On Sat, 14 Mar 2020, Satish Balay via petsc-users wrote:
> to work around - you can try:
> Satish
> > Its the same location as before. For some reason configure is not saving the relevant logs.
> > I don't understand saveLog() restoreLog() stuff. Matt, can you check on this?
> > Satish
> > On Sat, 14 Mar 2020, Fande Kong wrote:
> > > The configuration crashed earlier than before with your changes.
> > > Please see the attached log file when using your branch. The trouble lines
> > > should be:
> > >  "    asub=self.mangleFortranFunction("asub")
> > >     cbody = "extern void "+asub+"(void);\nint main(int argc,char
> > > **args)\n{\n  "+asub+"();\n  return 0;\n}\n";
> > > Thanks,
> > > Fande,
> > > On Thu, Mar 12, 2020 at 7:06 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > I can't figure out what the stack in the attached configure.log. [likely
> > > > some stuff isn't getting logged in it]
> > > > Can you retry with branch 'balay/fix-checkFortranLibraries/maint'?
> > > > Satish
> > > > On Thu, 12 Mar 2020, Fande Kong wrote:
> > > > > Thanks, Satish,
> > > > > But still have the problem. Please see the attached log file.
> > > > > Thanks,
> > > > > Fande.
> > > > > On Thu, Mar 12, 2020 at 3:42 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > > > Can you retry with the attached patch?
> > > > > > BTW: Its best to use the latest patched version - i.e
> > > > petsc-3.12.4.tar.gz
> > > > > > Satish
> > > > > > > This fixed the fblaslapack issue. Now have another issue about mumps.
> > > > > > > Please see the log file attached.
> > > > > > > Thanks,
> > > > > > > Fande,
> > > > > > > On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <balay at mcs.anl.gov>
> > > > wrote:
> > > > > > > > For some reason - the fortran compiler libraries check worked fine
> > > > > > without
> > > > > > > > -lgfortran.
> > > > > > > > But now - flbaslapack check is failing without it.
> > > > > > > > To work arround - you can use option LIBS=-lgfortran
> > > > > > > > Satish
> > > > > > > > > Hi All,
> > > > > > > > > I had an issue when configuring petsc on a linux machine. I have
> > > > the
> > > > > > > > > following error message:
> > > > > > > > >      Compiling FBLASLAPACK; this may take several minutes
> > > > > > > > >    TESTING: checkLib from
> > > > config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > > > > > > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see
> > > > > > configure.log for
> > > > > > > > > details):
> > > > > > > > > The configuration log was attached.
> > > > > > > > > Thanks,
> > > > > > > > > Fande,
