[petsc-users] --download-fblaslapack libraries cannot be used
Fande Kong fdkong.jd at gmail.com
Thu Mar 12 16:07:43 CDT 2020
This did not help.  Made no difference.
Fande,
On Thu, Mar 12, 2020 at 1:50 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Does the attached patch make a difference?
> Satish
> On Thu, 12 Mar 2020, Satish Balay via petsc-users wrote:
> > For some reason - the fortran compiler libraries check worked fine
> without -lgfortran.
> > But now - flbaslapack check is failing without it.
> > To work arround - you can use option LIBS=-lgfortran
> > Satish
> > On Thu, 12 Mar 2020, Fande Kong wrote:
> > > Hi All,
> > > I had an issue when configuring petsc on a linux machine. I have the
> > > following error message:
> > >      Compiling FBLASLAPACK; this may take several minutes
> > >    TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > The configuration log was attached.
> > > Thanks,
> > > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200312/2b5c55f2/attachment.html>
