[petsc-users] --download-fblaslapack libraries cannot be used
Fande Kong fdkong.jd at gmail.com
Thu Mar 12 16:07:13 CDT 2020
This fixed the fblaslapack issue. Now have another issue about mumps.
Please see the log file attached.
Fande,
On Thu, Mar 12, 2020 at 1:38 PM Satish Balay <balay at mcs.anl.gov> wrote:
> For some reason - the fortran compiler libraries check worked fine without
> -lgfortran.
> But now - flbaslapack check is failing without it.
> To work arround - you can use option LIBS=-lgfortran
> Satish
> On Thu, 12 Mar 2020, Fande Kong wrote:
> > Hi All,
> > I had an issue when configuring petsc on a linux machine. I have the
> > following error message:
> >      Compiling FBLASLAPACK; this may take several minutes
> >    TESTING: checkLib from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:120)
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > The configuration log was attached.
> > Thanks,
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200312/b243b284/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200312/b243b284/attachment-0001.obj>
