[petsc-users] PETSc and Windows 10
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Mon Jun 29 11:34:27 CDT 2020
> On 29 Jun 2020, at 6:27 PM, Paolo Lampitella <paololampitella at hotmail.com> wrote:
> I think I made the first step of having mingw64 from msys2 working with ms-mpi.
> I found that the issue I was having was related to:
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91556 <https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91556>
> and, probably (but impossible to check now), I was using an msys2 and/or mingw mpi package before this fix:
> https://github.com/msys2/MINGW-packages/commit/11b4cff3d2ec7411037b692b0ad5a9f3e9b9978d#diff-eac59989e3096be97d940c8f47b50fba <https://github.com/msys2/MINGW-packages/commit/11b4cff3d2ec7411037b692b0ad5a9f3e9b9978d#diff-eac59989e3096be97d940c8f47b50fba>
> Admittedly, I never used gcc 10 before on any machine. Still, I feel that reporting that sort of error in that way is,
> at least, misleading (I would have preferred the initial implementation as mentioned in the gcc bug track).
> A second thing that I was not used to, and made me more uncertain of the procedure I was following, is having to compile myself the mpi module. There are several version of this out there, but I decided to stick with this one:
> https://www.scivision.dev/windows-mpi-msys2/ <https://www.scivision.dev/windows-mpi-msys2/>
> even if there seems to be no need to include -fno-range-check and the current mpi.f90 version is different from the mpif.h as reported here:
> https://github.com/microsoft/Microsoft-MPI/issues/33 <https://github.com/microsoft/Microsoft-MPI/issues/33>
> which, to me, are both signs of lack of attention on the fortran side by those that maintain this thing.
> In summary, this is the procedure I followed so far (on a 64 bit machine with Windows 10):
> Install MSYS2 from https://www.msys2.org/ <https://www.msys2.org/> and just follow the install wizard
> Open the MSYS2 terminal and execute: pacman -Syuu
> Close the terminal when asked and reopen it
> Keep executing ‘pacman -Syuu’ until nothing else needs to be updated
> Close the MSYS2 terminal and reopen it (I guess because was in paranoid mode), then install packages with:
> pacman -S base-devel git gcc gcc-fortran bsdcpio lndir pax-git unzip
> pacman -S mingw-w64-x86_64-toolchain
> pacman -S mingw-w64-x86_64-msmpi
> pacman -S mingw-w64-x86_64-cmake
> pacman -S mingw-w64-x86_64-freeglut
> pacman -S mingw-w64-x86_64-gsl
> pacman -S mingw-w64-x86_64-libmicroutils
> pacman -S mingw-w64-x86_64-hdf5
> pacman -S mingw-w64-x86_64-openblas
> pacman -S mingw-w64-x86_64-arpack
> pacman -S mingw-w64-x86_64-jq
> This set should include all the libraries mentioned by Pierre and/or used by his Jenkins, as the final scope here is to have PETSc and dependencies working. But I think that for pure MPI one could stop to msmpi (even, maybe, just install msmpi and have the dependencies figured out by pacman). Honestly, I don’t remember the exact order I used to install the packages, but this should not affect things. Also, as I was still in paranoid mode, I kept executing ‘pacman -Syuu’ after each package was installed. After this, close the MSYS2 terminal.
> Open the MINGW64 terminal and create the .mod file out of the mpi.f90 file, as mentioned here https://www.scivision.dev/windows-mpi-msys2/ <https://www.scivision.dev/windows-mpi-msys2/>, with:
> cd /mingw64/include
> gfortran mpif90 -c -fno-range-check -fallow-invalid-boz
Ah, yes, that’s new to gfortran 10 (we use gfortran 9 on our workers), which is now what’s ship with MSYS2 (we haven’t updated yet). Sorry that I forgot about that.
> This is needed to ‘USE mpi’ (as opposed to INCLUDE ‘mpif.h’)
> Install the latest MS-MPI (both sdk and setup) from https://www.microsoft.com/en-us/download/details.aspx?id=100593 <https://www.microsoft.com/en-us/download/details.aspx?id=100593>
> At this point I’ve been able to compile (using the MINGW64 terminal) different mpi test programs and they run as expected in the classical Windows prompt. I added this function to my .bashrc in MSYS2 in order to easily copy the required dependencies out of MSYS:
> function copydep() { ldd $1 | grep "=> /$2" | awk '{print $3}' | xargs -I '{}' cp -v '{}' .; }
> which can be used, with the MINGW64 terminal, by navigating to the folder where the final executable, say, my.exe, resides (even if under a Windows path) and executing:
> copydep my.exe mingw64
> This, of course, must be done before actually trying to execute the .exe in the windows cmd prompt.
> Hopefully, I should now be able to follow Pierre’s instructions for PETSc (but first I wanna give a try to the system python before removing it)
Looks like the hard part is over. It’s usually easier to deal with ./configure issues.
If you have weird errors like “incomplete Cygwin install” or whatever, this is the kind of issues I was referring to earlier.
In that case, what I’d suggest is just, as before:
pacman -R mingw-w64-x86_64-python mingw-w64-x86_64-gdb
pacman -S python
Pierre
> Thanks
> Paolo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200629/d4494ab8/attachment.html>
