[petsc-users] R: PETSc and Windows 10
Paolo Lampitella paololampitella at hotmail.com
Mon Jun 29 11:27:54 CDT 2020
I think I made the first step of having mingw64 from msys2 working with ms-mpi.
I found that the issue I was having was related to:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91556
and, probably (but impossible to check now), I was using an msys2 and/or mingw mpi package before this fix:
https://github.com/msys2/MINGW-packages/commit/11b4cff3d2ec7411037b692b0ad5a9f3e9b9978d#diff-eac59989e3096be97d940c8f47b50fba
Admittedly, I never used gcc 10 before on any machine. Still, I feel that reporting that sort of error in that way is,
at least, misleading (I would have preferred the initial implementation as mentioned in the gcc bug track).
A second thing that I was not used to, and made me more uncertain of the procedure I was following, is having to compile myself the mpi module. There are several version of this out there, but I decided to stick with this one:
https://www.scivision.dev/windows-mpi-msys2/
even if there seems to be no need to include -fno-range-check and the current mpi.f90 version is different from the mpif.h as reported here:
https://github.com/microsoft/Microsoft-MPI/issues/33
which, to me, are both signs of lack of attention on the fortran side by those that maintain this thing.
In summary, this is the procedure I followed so far (on a 64 bit machine with Windows 10):
  *   Install MSYS2 from https://www.msys2.org/ and just follow the install wizard
  *   Open the MSYS2 terminal and execute: pacman -Syuu
  *   Close the terminal when asked and reopen it
  *   Keep executing ‘pacman -Syuu’ until nothing else needs to be updated
  *   Close the MSYS2 terminal and reopen it (I guess because was in paranoid mode), then install packages with:
pacman -S base-devel git gcc gcc-fortran bsdcpio lndir pax-git unzip
pacman -S mingw-w64-x86_64-toolchain
pacman -S mingw-w64-x86_64-msmpi
pacman -S mingw-w64-x86_64-cmake
pacman -S mingw-w64-x86_64-freeglut
pacman -S mingw-w64-x86_64-gsl
pacman -S mingw-w64-x86_64-libmicroutils
pacman -S mingw-w64-x86_64-hdf5
pacman -S mingw-w64-x86_64-openblas
pacman -S mingw-w64-x86_64-arpack
pacman -S mingw-w64-x86_64-jq
This set should include all the libraries mentioned by Pierre and/or used by his Jenkins, as the final scope here is to have PETSc and dependencies working. But I think that for pure MPI one could stop to msmpi (even, maybe, just install msmpi and have the dependencies figured out by pacman). Honestly, I don’t remember the exact order I used to install the packages, but this should not affect things. Also, as I was still in paranoid mode, I kept executing ‘pacman -Syuu’ after each package was installed. After this, close the MSYS2 terminal.
  *   Open the MINGW64 terminal and create the .mod file out of the mpi.f90 file, as mentioned here https://www.scivision.dev/windows-mpi-msys2/, with:
cd /mingw64/include
gfortran mpif90 -c -fno-range-check -fallow-invalid-boz
This is needed to ‘USE mpi’ (as opposed to INCLUDE ‘mpif.h’)
  *   Install the latest MS-MPI (both sdk and setup) from https://www.microsoft.com/en-us/download/details.aspx?id=100593
At this point I’ve been able to compile (using the MINGW64 terminal) different mpi test programs and they run as expected in the classical Windows prompt. I added this function to my .bashrc in MSYS2 in order to easily copy the required dependencies out of MSYS:
function copydep() { ldd $1 | grep "=> /$2" | awk '{print $3}' | xargs -I '{}' cp -v '{}' .; }
which can be used, with the MINGW64 terminal, by navigating to the folder where the final executable, say, my.exe, resides (even if under a Windows path) and executing:
copydep my.exe mingw64
This, of course, must be done before actually trying to execute the .exe in the windows cmd prompt.
Hopefully, I should now be able to follow Pierre’s instructions for PETSc (but first I wanna give a try to the system python before removing it)
Thanks
Paolo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200629/d97b5cfe/attachment-0001.html>
