[petsc-users] PETSc initialization error
Junchao Zhang
junchao.zhang at gmail.com
Sat Jun 20 10:54:16 CDT 2020
I don't understand what your session means. Let's try this patch
diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
index d559a513..c058265d 100644
--- a/src/sys/mpiuni/mpi.c
+++ b/src/sys/mpiuni/mpi.c
@@ -283,6 +283,7 @@ int MPI_Finalize(void)
MPI_Comm_free(&comm);
comm = MPI_COMM_SELF;
+ num_attr = 1; /* reset the counter */
MPI_was_finalized = 1;
return MPI_SUCCESS;
--Junchao Zhang
On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Typo: I mean “Assuming initializer is only needed once for entire session”
> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Assuming finalizer is only needed once for entire session(?), I can put
>> initializer into the static block to call it once but where do I call
>> finalizer?
>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> The counter num_attr should be recycled. But first try to call PETSc
>>> initialize/Finalize only once to see it fixes the error.
>>> --Junchao Zhang
>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> To clarify, I call PETSc initialize and PETSc finalize everytime I call
>>>> SLEPc:
>>>> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>> //calling slepc
>>>> SlepcFinalize();
>>>> PetscFinalize();
>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Dear PETSc team,
>>>>> When I called SLEPc multiple time, I eventually got following
>>>>> error:
>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>> ../../../petsc/src/sys/objects/pinit.c
>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>> ../../../slepc/src/sys/slepcinit.c
>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>> PETSC ERROR: Logging has not been enabled.
>>>>> You might have forgotten to call PetscInitialize().
>>>>> I debugged: it is because of following in petsc/src/sys/mpiuni/mpi.c
>>>>> if (num_attr >= MAX_ATTR)
>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>>> num_attr is declared static and keeps increasing every
>>>>> time MPI_Comm_create_keyval is called.
>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>> Is this a bug or I didn't use it correctly?
>>>>> Thanks,
>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/78d8a84f/attachment-0001.html>
