[petsc-users] PETSc initialization error
Sam Guo
sam.guo at cd-adapco.com
Sat Jun 20 10:48:43 CDT 2020
Typo: I mean “Assuming initializer is only needed once for entire session”
On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Assuming finalizer is only needed once for entire session(?), I can put
> initializer into the static block to call it once but where do I call
> finalizer?
> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com> wrote:
>> The counter num_attr should be recycled. But first try to call PETSc
>> initialize/Finalize only once to see it fixes the error.
>> --Junchao Zhang
>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> To clarify, I call PETSc initialize and PETSc finalize everytime I call
>>> SLEPc:
>>> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>> //calling slepc
>>> SlepcFinalize();
>>> PetscFinalize();
>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Dear PETSc team,
>>>> When I called SLEPc multiple time, I eventually got following error:
>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>> ../../../petsc/src/sys/objects/pinit.c
>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>> ../../../slepc/src/sys/slepcinit.c
>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>> PETSC ERROR: Logging has not been enabled.
>>>> You might have forgotten to call PetscInitialize().
>>>> I debugged: it is because of following in petsc/src/sys/mpiuni/mpi.c
>>>> if (num_attr >= MAX_ATTR)
>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>> num_attr is declared static and keeps increasing every
>>>> time MPI_Comm_create_keyval is called.
>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>> Is this a bug or I didn't use it correctly?
>>>> Thanks,
>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/8a5cf74b/attachment.html>
