[petsc-users] PETSc initialization error
Junchao Zhang
junchao.zhang at gmail.com
Sat Jun 20 08:53:38 CDT 2020
The counter num_attr should be recycled. But first try to call PETSc
initialize/Finalize only once to see it fixes the error.
--Junchao Zhang
On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
> To clarify, I call PETSc initialize and PETSc finalize everytime I call
> SLEPc:
> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
> //calling slepc
> SlepcFinalize();
> PetscFinalize();
> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Dear PETSc team,
>> When I called SLEPc multiple time, I eventually got following error:
>> MPI operation not supported by PETSc's sequential MPI wrappers
>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>> ../../../petsc/src/sys/objects/pinit.c
>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>> ../../../slepc/src/sys/slepcinit.c
>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>> PETSC ERROR: Logging has not been enabled.
>> You might have forgotten to call PetscInitialize().
>> I debugged: it is because of following in petsc/src/sys/mpiuni/mpi.c
>> if (num_attr >= MAX_ATTR)
>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>> num_attr is declared static and keeps increasing every
>> time MPI_Comm_create_keyval is called.
>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>> Is this a bug or I didn't use it correctly?
>> Thanks,
>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200620/b53bcc11/attachment.html>
