[petsc-users] configure error
Kun Jiao
KJiao at slb.com
Mon Jun 15 12:11:43 CDT 2020
Lately I run into a configure error with intel compiler+openmpi+lapack,
Error message as:
=============================================================================== TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:114) *******************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
You set a value for --with-blaslapack-lib=<lib>, but ['-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64', '-Wl,', '--no-as-needed', '-lmkl_intel_ilp64', '-lmkl_intel_thread', '-lmkl_core', '-liomp5', '-lpthread', '-lm', '-ldl'] cannot be used
Here is my configure parameters:
./configure --configModules=PETSc.Configure --optionsModule=config.compilerOptions --configModules=PETSc.Configure --optionsModule=config.compilerOptions PETSC_ARCH=linux-gnu-intel --with-precision=single --with-cc=icc --with-cxx=icc --with-fc=ifort --with-mpi-include=/opt/openmpi_4.0.3_intel2019.3/include --with-mpi-lib="-L/opt/openmpi_4.0.3_intel2019.3/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi" --with-blaslapack-include="/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/include" --with-blaslapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64 -Wl, --no-as-needed -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -lm -ldl" --with-scalapack-lib="-L/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" --with-scalapack-include=/mnt/disks/intel-2018-3-222-blade-runtime-env-2018-1-07-08-2018-132838/2019.3/intel/compilers_and_libraries_2019.3.199/linux/mkl/include --with-cmake=1 --prefix=/opt/petsc_3.10.4_intel2019.3 --known-endian=big --with-debugging=0 --COPTFLAGS=" -Ofast -xHost" --CXXOPTFLAGS=" -Ofast -xHost" --FOPTLAGS=" -Ofast -xHost" --with-x=0 --with-64-bit-indices
And configure.log attached.
Any suggestion will be great?
Kun
Schlumberger-Private
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200615/075e7d0f/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200615/075e7d0f/attachment-0001.obj>
