[petsc-users] Debugging suggestions: GAMG
Sanjay Govindjee
s_g at berkeley.edu
Sun Jun 14 02:29:55 CDT 2020
That worked. Thanks.
On 6/14/20 12:19 AM, Barry Smith wrote:
> You should be able to use the option
> -fp_trap on
> to resolve this problem. I am working on a general fix but it is
> extensive and has to go into the master branch and cannot be back ported.
> Barry
>> On Jun 13, 2020, at 3:06 PM, Sanjay Govindjee <s_g at berkeley.edu
>> <mailto:s_g at berkeley.edu>> wrote:
>> Not a lot of luck here; I guess I don't know how to set the break
>> point correctly?
>> (gdb) b ieee_handler
>> Function "ieee_handler" not defined.
>> Make breakpoint pending on future shared library load? (y or [n]) y
>> Breakpoint 1 (ieee_handler) pending.
>> (gdb) c
>> Continuing.
>> Thread 1 "feap" received signal SIGFPE, Arithmetic exception.
>> 0x00007f8d1a422be1 in ieeeck_ () from /lib64/liblapack.so.3
>> On 6/13/20 9:04 AM, Barry Smith wrote:
>>> You could try in gdb to put a break point in ieee_handler and find
>>> all the places it gets called, maybe this will lead to the location
>>> of the cause.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200614/a702c22a/attachment-0001.html>
