[petsc-users] Debugging suggestions: GAMG
Barry Smith
bsmith at petsc.dev
Sat Jun 13 15:35:03 CDT 2020
I can reproduce the crash, so I will debug it and let you know the results.
Thanks for all your help
Barry
> On Jun 13, 2020, at 3:06 PM, Sanjay Govindjee <s_g at berkeley.edu> wrote:
> Not a lot of luck here; I guess I don't know how to set the break point correctly?
> (gdb) b ieee_handler
> Function "ieee_handler" not defined.
> Make breakpoint pending on future shared library load? (y or [n]) y
> Breakpoint 1 (ieee_handler) pending.
> (gdb) c
> Continuing.
> Thread 1 "feap" received signal SIGFPE, Arithmetic exception.
> 0x00007f8d1a422be1 in ieeeck_ () from /lib64/liblapack.so.3
> On 6/13/20 9:04 AM, Barry Smith wrote:
>> You could try in gdb to put a break point in ieee_handler and find all the places it gets called, maybe this will lead to the location of the cause.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200613/039dcb7c/attachment.html>
