[petsc-users] Debugging suggestions: GAMG
Sanjay Govindjee s_g at berkeley.edu
Sat Jun 13 15:06:07 CDT 2020
Not a lot of luck here; I guess I don't know how to set the break point
correctly?
    (gdb) b ieee_handler
    Function "ieee_handler" not defined.
    Make breakpoint pending on future shared library load? (y or [n]) y
    Breakpoint 1 (ieee_handler) pending.
    (gdb) c
    Continuing.
    Thread 1 "feap" received signal SIGFPE, Arithmetic exception.
    0x00007f8d1a422be1 in ieeeck_ () from /lib64/liblapack.so.3
On 6/13/20 9:04 AM, Barry Smith wrote:
> You could try in gdb to put a break point in ieee_handler and find all
> the places it gets called, maybe this will lead to the location of the
> cause.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200613/6f1ff667/attachment.html>
