[petsc-users] MatGetRow for global rows of a parallel matrix
Matthew Knepley
knepley at gmail.com
Wed Jun 10 08:16:36 CDT 2020
On Wed, Jun 10, 2020 at 9:08 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Dear Matt,
> Matthew Knepley <knepley at gmail.com>, 10 Haz 2020 Çar, 16:03 tarihinde
> şunu yazdı:
> > On Wed, Jun 10, 2020 at 8:56 AM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> >> Hi all,
> >> I am trying to get all the rows of a parallel matrix as individual
> >> vectors. For instance, if I have 72*4 matrix, I want to get 72
> >> different vectors having size 4.
> >> As far as I understood, MatGetRow is only for local rows, so
> >> MatGetOwnershipRange is used, however, when I tried this one, I
> >> couldn't get the whole and desired row vectors.
> >> In MatGetRow explanation, it is written that I should use
> >> MatCreateSubMatrices first, then use MatGetRow. But I couldn't
> >> understand to which extent I should create submatrices. I just need to
> >> have all 72 rows as 72 different vectors each having 4 elements.
> > 1) For sparse matrices, the storage is always divided by row, so that
> values can only be retrieved for local rows with MatGetRow()
> > 2) Is this matrix sparse? It sounds like it is dense.
> Matrix is dense.
> > 3) Are you asking to get all matrix values on all processes? If so, I
> think the easiest thing to do is first wrap a Vec around the
> > values, then use VecScatterToAll(), then wrap each one in a MatDense
> again.
> Yes, I want all row vectors on all processes. In a dense matrix,
> should I still wrap a Vec around the values? I know I should use
> scatter but I couldn't even wrap a Vec around them.
I would do
MatGetSize(&N);
MatGetLocalSize(&m);
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatDenseGetArray.html
<create vector of local size m*N>
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecPlaceArray.html
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html
<do scatter>
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecResetArray.html#VecResetArray
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateDense.html
<use it>
<destroy matrix>
<destroy vector from CreateToAll>
Matt
> Thanks so much!
> Eda
> > Thanks,
> > Matt
> >> Thanks!
> >> Eda
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200610/1eb87e9f/attachment.html>
