[petsc-users] Make stream
Fande Kong
fdkong.jd at gmail.com
Tue Jun 9 19:03:11 CDT 2020
Thanks so much, Barry,
On Tue, Jun 9, 2020 at 3:08 PM Barry Smith <bsmith at petsc.dev> wrote:
> You might look at the notes about MPI binding. It might give you a bit
> better performance.
> https://www.mcs.anl.gov/petsc/documentation/faq.html#computers
I am using mvapich2, and still trying to look for which binding command
lines I can use.
> The streams is exactly the DAXPY operation so this is the speed up you
> should expect for VecAXPY() which has 2 loads and 1 store per 1 multipy and
> 1 add
> VecDot() has 2 loads per 1 multiply and 1 add but also a global
> reduction
> Sparse multiply with AIJ has an integer load, 2 double loads plus 1
> store per row with 1 multiply and 1 add plus communication needed for
> off-process portion
> Function evaluations often have higher arithmetic intensity so should
> give a bit higher speedup
> Jacobian evaluations often have higher arithmetic intensity but they
> may have MatSetValues() which is slow because no arithmetic intensity just
> memory motion
Got it.
Fande,
> Barry
> On Jun 9, 2020, at 3:43 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi All,
> I am trying to interpret the results from "make stream" on two compute
> nodes, where each node has 48 cores.
> If my calculations are memory bandwidth limited, such as AMG, MatVec,
> GMRES, etc..
> The best speedup I could get is 16.6938 if I start from one core?? The
> speedup for function evaluations and Jacobian evaluations can be better
> than16.6938?
> Thanks,
> Fande,
> Running streams with 'mpiexec ' using 'NPMAX=96'
> 1 19412.4570 Rate (MB/s)
> 2 29457.3988 Rate (MB/s) 1.51744
> 3 40483.9318 Rate (MB/s) 2.08546
> 4 51429.3431 Rate (MB/s) 2.64929
> 5 59849.5168 Rate (MB/s) 3.08304
> 6 66124.3461 Rate (MB/s) 3.40628
> 7 70888.1170 Rate (MB/s) 3.65167
> 8 73436.2374 Rate (MB/s) 3.78294
> 9 77441.7622 Rate (MB/s) 3.98927
> 10 78115.3114 Rate (MB/s) 4.02397
> 11 81449.3315 Rate (MB/s) 4.19572
> 12 82812.3471 Rate (MB/s) 4.26593
> 13 81442.2114 Rate (MB/s) 4.19535
> 14 83404.1657 Rate (MB/s) 4.29642
> 15 84165.8536 Rate (MB/s) 4.33565
> 16 83739.2910 Rate (MB/s) 4.31368
> 17 83724.8109 Rate (MB/s) 4.31293
> 18 83225.0743 Rate (MB/s) 4.28719
> 19 81668.2002 Rate (MB/s) 4.20699
> 20 83678.8007 Rate (MB/s) 4.31056
> 21 81400.4590 Rate (MB/s) 4.1932
> 22 81944.8975 Rate (MB/s) 4.22124
> 23 81359.8615 Rate (MB/s) 4.19111
> 24 80674.5064 Rate (MB/s) 4.1558
> 25 83761.3316 Rate (MB/s) 4.31481
> 26 87567.4876 Rate (MB/s) 4.51088
> 27 89605.4435 Rate (MB/s) 4.61586
> 28 94984.9755 Rate (MB/s) 4.89298
> 29 98260.5283 Rate (MB/s) 5.06171
> 30 99852.8790 Rate (MB/s) 5.14374
> 31 102736.3576 Rate (MB/s) 5.29228
> 32 108638.7488 Rate (MB/s) 5.59633
> 33 110431.2938 Rate (MB/s) 5.68867
> 34 112824.2031 Rate (MB/s) 5.81194
> 35 116908.3009 Rate (MB/s) 6.02232
> 36 121312.6574 Rate (MB/s) 6.2492
> 37 122507.3172 Rate (MB/s) 6.31074
> 38 127456.2504 Rate (MB/s) 6.56568
> 39 130098.7056 Rate (MB/s) 6.7018
> 40 134956.4461 Rate (MB/s) 6.95204
> 41 138309.2465 Rate (MB/s) 7.12475
> 42 141779.7997 Rate (MB/s) 7.30353
> 43 145653.3687 Rate (MB/s) 7.50307
> 44 149131.2087 Rate (MB/s) 7.68223
> 45 151611.6104 Rate (MB/s) 7.81
> 46 155554.6394 Rate (MB/s) 8.01312
> 47 159033.1938 Rate (MB/s) 8.19231
> 48 162216.5600 Rate (MB/s) 8.35629
> 49 165034.8116 Rate (MB/s) 8.50147
> 50 168001.4823 Rate (MB/s) 8.65429
> 51 170899.9045 Rate (MB/s) 8.8036
> 52 175687.8033 Rate (MB/s) 9.05024
> 53 178203.9203 Rate (MB/s) 9.17985
> 54 179973.3914 Rate (MB/s) 9.27101
> 55 182207.3495 Rate (MB/s) 9.38608
> 56 185712.9643 Rate (MB/s) 9.56667
> 57 188805.5696 Rate (MB/s) 9.72598
> 58 193360.9158 Rate (MB/s) 9.96064
> 59 198160.8016 Rate (MB/s) 10.2079
> 60 201297.0129 Rate (MB/s) 10.3695
> 61 203618.7672 Rate (MB/s) 10.4891
> 62 209599.2783 Rate (MB/s) 10.7971
> 63 211651.1587 Rate (MB/s) 10.9028
> 64 210254.5035 Rate (MB/s) 10.8309
> 65 218576.4938 Rate (MB/s) 11.2596
> 66 220280.0853 Rate (MB/s) 11.3473
> 67 221281.1867 Rate (MB/s) 11.3989
> 68 228941.1872 Rate (MB/s) 11.7935
> 69 232206.2708 Rate (MB/s) 11.9617
> 70 233569.5866 Rate (MB/s) 12.0319
> 71 238293.6355 Rate (MB/s) 12.2753
> 72 238987.0729 Rate (MB/s) 12.311
> 73 246013.4684 Rate (MB/s) 12.6729
> 74 248850.8942 Rate (MB/s) 12.8191
> 75 249355.6899 Rate (MB/s) 12.8451
> 76 252515.6110 Rate (MB/s) 13.0079
> 77 257489.4268 Rate (MB/s) 13.2641
> 78 260884.2771 Rate (MB/s) 13.439
> 79 264341.8661 Rate (MB/s) 13.6171
> 80 269329.1376 Rate (MB/s) 13.874
> 81 272286.4070 Rate (MB/s) 14.0263
> 82 273325.7822 Rate (MB/s) 14.0799
> 83 277334.6699 Rate (MB/s) 14.2864
> 84 280254.7286 Rate (MB/s) 14.4368
> 85 282219.8194 Rate (MB/s) 14.538
> 86 289039.2677 Rate (MB/s) 14.8893
> 87 291234.4715 Rate (MB/s) 15.0024
> 88 295941.1159 Rate (MB/s) 15.2449
> 89 298136.3163 Rate (MB/s) 15.358
> 90 302820.9080 Rate (MB/s) 15.5993
> 91 306387.5008 Rate (MB/s) 15.783
> 92 310127.0223 Rate (MB/s) 15.9756
> 93 310219.3643 Rate (MB/s) 15.9804
> 94 317089.5971 Rate (MB/s) 16.3343
> 95 315457.0938 Rate (MB/s) 16.2502
> 96 324068.8172 Rate (MB/s) 16.6938
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200609/e535882b/attachment.html>
