[petsc-users] Make stream
Barry Smith bsmith at petsc.dev
Tue Jun 9 16:08:22 CDT 2020
   You might look at the notes about MPI binding. It might give you a bit better performance. https://www.mcs.anl.gov/petsc/documentation/faq.html#computers <https://www.mcs.anl.gov/petsc/documentation/faq.html#computers>
   The streams is exactly the DAXPY operation so this is the speed up you should expect for VecAXPY() which has 2 loads and 1 store per 1 multipy and 1 add
   VecDot() has 2 loads per 1 multiply and 1 add but also a global reduction
   Sparse multiply with AIJ has an integer load, 2 double loads plus 1 store per row with 1 multiply and 1 add plus communication needed for off-process portion
   Function evaluations often have higher arithmetic intensity so should give a bit higher speedup
   Jacobian evaluations often have higher arithmetic intensity but they may have MatSetValues() which is slow because no arithmetic intensity just memory motion
   Barry
> On Jun 9, 2020, at 3:43 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi All,
> I am trying to interpret the results from "make stream" on two compute nodes, where each node has 48 cores.
> If my calculations are memory bandwidth limited, such as AMG, MatVec, GMRES, etc..
> The best speedup I could get is 16.6938 if I start from one core?? The speedup for function evaluations and Jacobian evaluations can be better than16.6938?
> Thanks,
> Fande,
> Running streams with 'mpiexec ' using 'NPMAX=96'
> 1 19412.4570  Rate (MB/s)
> 2 29457.3988  Rate (MB/s) 1.51744
> 3 40483.9318  Rate (MB/s) 2.08546
> 4 51429.3431  Rate (MB/s) 2.64929
> 5 59849.5168  Rate (MB/s) 3.08304
> 6 66124.3461  Rate (MB/s) 3.40628
> 7 70888.1170  Rate (MB/s) 3.65167
> 8 73436.2374  Rate (MB/s) 3.78294
> 9 77441.7622  Rate (MB/s) 3.98927
> 10 78115.3114  Rate (MB/s) 4.02397
> 11 81449.3315  Rate (MB/s) 4.19572
> 12 82812.3471  Rate (MB/s) 4.26593
> 13 81442.2114  Rate (MB/s) 4.19535
> 14 83404.1657  Rate (MB/s) 4.29642
> 15 84165.8536  Rate (MB/s) 4.33565
> 16 83739.2910  Rate (MB/s) 4.31368
> 17 83724.8109  Rate (MB/s) 4.31293
> 18 83225.0743  Rate (MB/s) 4.28719
> 19 81668.2002  Rate (MB/s) 4.20699
> 20 83678.8007  Rate (MB/s) 4.31056
> 21 81400.4590  Rate (MB/s) 4.1932
> 22 81944.8975  Rate (MB/s) 4.22124
> 23 81359.8615  Rate (MB/s) 4.19111
> 24 80674.5064  Rate (MB/s) 4.1558
> 25 83761.3316  Rate (MB/s) 4.31481
> 26 87567.4876  Rate (MB/s) 4.51088
> 27 89605.4435  Rate (MB/s) 4.61586
> 28 94984.9755  Rate (MB/s) 4.89298
> 29 98260.5283  Rate (MB/s) 5.06171
> 30 99852.8790  Rate (MB/s) 5.14374
> 31 102736.3576  Rate (MB/s) 5.29228
> 32 108638.7488  Rate (MB/s) 5.59633
> 33 110431.2938  Rate (MB/s) 5.68867
> 34 112824.2031  Rate (MB/s) 5.81194
> 35 116908.3009  Rate (MB/s) 6.02232
> 36 121312.6574  Rate (MB/s) 6.2492
> 37 122507.3172  Rate (MB/s) 6.31074
> 38 127456.2504  Rate (MB/s) 6.56568
> 39 130098.7056  Rate (MB/s) 6.7018
> 40 134956.4461  Rate (MB/s) 6.95204
> 41 138309.2465  Rate (MB/s) 7.12475
> 42 141779.7997  Rate (MB/s) 7.30353
> 43 145653.3687  Rate (MB/s) 7.50307
> 44 149131.2087  Rate (MB/s) 7.68223
> 45 151611.6104  Rate (MB/s) 7.81
> 46 155554.6394  Rate (MB/s) 8.01312
> 47 159033.1938  Rate (MB/s) 8.19231
> 48 162216.5600  Rate (MB/s) 8.35629
> 49 165034.8116  Rate (MB/s) 8.50147
> 50 168001.4823  Rate (MB/s) 8.65429
> 51 170899.9045  Rate (MB/s) 8.8036
> 52 175687.8033  Rate (MB/s) 9.05024
> 53 178203.9203  Rate (MB/s) 9.17985
> 54 179973.3914  Rate (MB/s) 9.27101
> 55 182207.3495  Rate (MB/s) 9.38608
> 56 185712.9643  Rate (MB/s) 9.56667
> 57 188805.5696  Rate (MB/s) 9.72598
> 58 193360.9158  Rate (MB/s) 9.96064
> 59 198160.8016  Rate (MB/s) 10.2079
> 60 201297.0129  Rate (MB/s) 10.3695
> 61 203618.7672  Rate (MB/s) 10.4891
> 62 209599.2783  Rate (MB/s) 10.7971
> 63 211651.1587  Rate (MB/s) 10.9028
> 64 210254.5035  Rate (MB/s) 10.8309
> 65 218576.4938  Rate (MB/s) 11.2596
> 66 220280.0853  Rate (MB/s) 11.3473
> 67 221281.1867  Rate (MB/s) 11.3989
> 68 228941.1872  Rate (MB/s) 11.7935
> 69 232206.2708  Rate (MB/s) 11.9617
> 70 233569.5866  Rate (MB/s) 12.0319
> 71 238293.6355  Rate (MB/s) 12.2753
> 72 238987.0729  Rate (MB/s) 12.311
> 73 246013.4684  Rate (MB/s) 12.6729
> 74 248850.8942  Rate (MB/s) 12.8191
> 75 249355.6899  Rate (MB/s) 12.8451
> 76 252515.6110  Rate (MB/s) 13.0079
> 77 257489.4268  Rate (MB/s) 13.2641
> 78 260884.2771  Rate (MB/s) 13.439
> 79 264341.8661  Rate (MB/s) 13.6171
> 80 269329.1376  Rate (MB/s) 13.874
> 81 272286.4070  Rate (MB/s) 14.0263
> 82 273325.7822  Rate (MB/s) 14.0799
> 83 277334.6699  Rate (MB/s) 14.2864
> 84 280254.7286  Rate (MB/s) 14.4368
> 85 282219.8194  Rate (MB/s) 14.538
> 86 289039.2677  Rate (MB/s) 14.8893
> 87 291234.4715  Rate (MB/s) 15.0024
> 88 295941.1159  Rate (MB/s) 15.2449
> 89 298136.3163  Rate (MB/s) 15.358
> 90 302820.9080  Rate (MB/s) 15.5993
> 91 306387.5008  Rate (MB/s) 15.783
> 92 310127.0223  Rate (MB/s) 15.9756
> 93 310219.3643  Rate (MB/s) 15.9804
> 94 317089.5971  Rate (MB/s) 16.3343
> 95 315457.0938  Rate (MB/s) 16.2502
> 96 324068.8172  Rate (MB/s) 16.6938
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200609/da577137/attachment.html>
