[petsc-users] Calling MATLAB code within a parallel C/C++ code
Amneet Bhalla mail2amneet at gmail.com
Tue Jun 9 16:20:57 CDT 2020
Do these additional configure flags for MATLAB look OK?
--with-matlab=1 --with-matlab-dir=/Applications/MATLAB_R2019b.app
--with-matlab-engine=1
--with-matlab-engine-dir=/Applications/MATLAB_R2019b.app/extern/engines/
With this configuration make compiled files like:
          CC darwin-dbg/obj/sys/classes/viewer/impls/matlab/vmatlab.o
          CC
darwin-dbg/obj/sys/classes/viewer/impls/matlab/ftn-custom/zvmatlabf.o
          CC darwin-dbg/obj/sys/classes/matlabengine/matlab.o
          CC darwin-dbg/obj/sys/classes/matlabengine/ftn-auto/matlabf.o
          CC darwin-dbg/obj/sys/classes/matlabengine/ftn-custom/zmatlabf.o
          CC darwin-dbg/obj/vec/pf/impls/matlab/cmatlab.o
          CC darwin-dbg/obj/vec/vec/utils/matlab/gcreatev.o
make[2]: Leaving directory `/Users/amneetb/Softwares/PETSc-Gitlab/PETSc'
BEGINNING TO COMPILE MATLAB INTERFACE
Building with 'Xcode with Clang'.
ld: warning: cannot export hidden symbol _mexfilerequiredapiversion from
c_mexapi_version.o
c_mexapi_version.o
MEX completed successfully.
c_mexapi_version.o
c_mexapi_version.o
c_mexapi_version.o
c_mexapi_version.o
c_mexapi_version.o
However, make check gives error
amneetb at Amneets-MBP:~/Softwares/PETSc-Gitlab/PETSc$ make
PETSC_DIR=/Users/amneetb/Softwares/PETSc-Gitlab/PETSc PETSC_ARCH=darwin-dbg
check
Running test examples to verify correct installation
Using PETSC_DIR=/Users/amneetb/Softwares/PETSc-Gitlab/PETSc and
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
dyld: Library not loaded: @rpath/libeng.dylib
  Referenced from:
/Users/amneetb/Softwares/PETSc-Gitlab/PETSc/src/snes/examples/tutorials/./ex19
  Reason: image not found
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 14057 RUNNING AT Amneets-MBP
=   EXIT CODE: 6
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Abort trap: 6 (signal 6)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
processes
  Referenced from:
  Referenced from:
=   PID 14062 RUNNING AT Amneets-MBP
=   EXIT CODE: 6
1,5c1,17
< lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
<   0 SNES Function norm 0.0406612
<   1 SNES Function norm 4.12227e-06
<   2 SNES Function norm 6.098e-11
< Number of SNES iterations = 2
>   Referenced from:
>   Referenced from:
> =   PID 14072 RUNNING AT Amneets-MBP
> =   EXIT CODE: 6
Possible problem with ex19 running with hypre, diffs above
Possible error running Fortran example src/snes/examples/tutorials/ex5f
with 1 MPI process
  Referenced from:
/Users/amneetb/Softwares/PETSc-Gitlab/PETSc/src/snes/examples/tutorials/./ex5f
=   PID 14211 RUNNING AT Amneets-MBP
=   EXIT CODE: 6
Completed test examples
I have added the following paths in my .profile and sourced it before make
all and make check
export DYLD_FALLBACK_LIBRARY_PATH=
/Applications/MATLAB_R2019b.app/bin/maci64:/Applications/MATLAB_R2019b.app/sys/os/maci64:
$DYLD_FALLBACK_LIBRARY_PATH
export DYLD_LIBRARY_PATH=
$DYLD_LIBRARY_PATH
On Mon, Jun 8, 2020 at 6:39 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Looks like the tool to list the examples in the manual pages is broken
> since it didn't find these other examples, I'll take a look at it.
>   There is also a discussion in the users manual
> $ git grep MatlabEngine | grep ex
> src/docs/tex/manual/part2.tex:PetscMatlabEngineCreate(MPI_Comm comm,char
> *machine,PetscMatlabEngine *e);
> src/docs/tex/manual/part2.tex:PetscMatlabEnginePut(PetscMatlabEngine
> e,PetscObject obj);
> src/docs/tex/manual/part2.tex:PetscMatlabEngineGet(PetscMatlabEngine
> e,PetscObject obj);
> src/docs/tex/manual/part2.tex:PetscMatlabEnginePutArray(PetscMatlabEngine
> e,int m,int n,PetscScalar *array,char *name);
> src/docs/tex/manual/part2.tex:PetscMatlabEngineGetArray(PetscMatlabEngine
> src/docs/tex/manual/part2.tex:PetscMatlabEngineEvaluate(PetscMatlabEngine,"format",...);
> src/docs/tex/manual/part2.tex:PetscMatlabEngineEvaluate(PetscMatlabEngine,"x
> = \%g *y + z;",avalue);
> src/docs/tex/manual/part2.tex:PetscMatlabEngineGetOutput(PetscMatlabEngine,char
> src/docs/tex/manual/part2.tex:PetscMatlabEnginedPrintOutput(PetscMatlabEngine,FILE*).
> src/snes/tutorials/ex5.c:  ierr =
> PetscMatlabEnginePut(PETSC_MATLAB_ENGINE_(comm),(PetscObject)localX);CHKERRQ(ierr);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(comm),"localF=ex5m(localX,%18.16e,%18.16e,%18.16e)",hx,hy,lambda);CHKERRQ(ierr);
> PetscMatlabEngineGet(PETSC_MATLAB_ENGINE_(comm),(PetscObject)localF);CHKERRQ(ierr);
> src/sys/tests/ex16.c:static char help[] = "Demonstrates
> PetscMatlabEngineXXX()\n";
> src/sys/tests/ex16.c:  ierr =
> PetscMatlabEngineGetOutput(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),&output);CHKERRQ(ierr);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),"MPI_Comm_rank");CHKERRQ(ierr);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_(PETSC_COMM_WORLD),user);CHKERRQ(ierr);
> src/vec/vec/tests/ex31.c:static const char help[] = "Demonstrates
> src/vec/vec/tests/ex31.c:  ierr =
> PetscMatlabEngineGetOutput(PETSC_MATLAB_ENGINE_WORLD,&output);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"MPI_Comm_rank");
> PetscMatlabEnginePut(PETSC_MATLAB_ENGINE_WORLD,(PetscObject)x);CHKERRQ(ierr);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"x = x +
> MPI_Comm_rank;\n");
> PetscMatlabEngineGet(PETSC_MATLAB_ENGINE_WORLD,(PetscObject)x);CHKERRQ(ierr);
> PetscMatlabEngineEvaluate(PETSC_MATLAB_ENGINE_WORLD,"whos\n");CHKERRQ(ierr);
> On Jun 8, 2020, at 8:26 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
> Great!
> Clicking on some of the functions pointed me to this example
> https://www.mcs.anl.gov/petsc/petsc-3.13/src/snes/tutorials/ex5.c.html
> Are there more examples, which are perhaps simpler than the above, which I
> can refer to?
> On Mon, Jun 8, 2020 at 5:51 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   You should use the PetscMatlabEngine
>> https://www.mcs.anl.gov/petsc/petsc-3.13/docs/manualpages/Sys/PetscMatlabEngine.html
>>   Barry
>> On Jun 8, 2020, at 7:09 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
>> Hi Folks,
>> My parallel application written in C++ (which also uses PETSc library for
>> linear solvers) requires calling control and optimization toolbox of MATLAB
>> at every time step to get a small number of double values. Likewise the
>> MATLAB function will need to know some values from the parallel C++
>> application to return those doubles. I'm wondering if there is a
>> recommended way of calling MATLAB from parallel C/C++/Fortran codes, and if
>> PETSc has some interface that could be leveraged for this exchange.
>> Thanks,
>> --Amneet
> --Amneet
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200609/05d5d6d1/attachment-0001.html>
