[petsc-users] Norm_2 calculation
Fazlul Huq huq2090 at gmail.com
Fri Jun 5 14:08:29 CDT 2020
Thanks for the hint!
I will look at the matrix more closely.
For reference:
  if (!rstart) {
    rstart = 1;
    i      = 0; col[0] = 0; col[1] = 1; value[0] = 2.0; value[1] = -1.0;
    ierr   = MatSetValues(A,1,&i,2,col,value,INSERT_VALUES);CHKERRQ(ierr);
  if (rend == n) {
    rend = n-1;
    i    = n-1; col[0] = n-2; col[1] = n-1; value[0] = -1.0; value[1] = 2.0;
  /* Set entries corresponding to the mesh interior */
  value[0] = -1.0; value[1] = 2.0; value[2] = -1.0;
  for (i=rstart; i<rend; i++) {
    col[0] = i-1; col[1] = i; col[2] = i+1;
    ierr   = MatSetValues(A,1,&i,3,col,value,INSERT_VALUES);CHKERRQ(ierr);
  /* Assemble the matrix */
  ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
Sincerely,
Huq
On Fri, Jun 5, 2020 at 1:53 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 5, 2020 at 2:18 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>> The same is happening with "-pc_type hypre -pc_hypre_type boomerang" and
>> with "-pc_type ilu".
>> I tried with,
>> ierr =
>> KSPSetTolerances(ksp,1.e-10,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>> this also.
>> Getting higher values of error even then.
> Always check with
>   -pc_type lu
> It seems likely that your matrix is flawed.
>   Thanks,
>      Matt
>> Any suggestion to go over this issue?
>> Shall I send the code? It's not a large script (single routine, less than
>> 100 lines except comment).
>> Thank you.
>> Sincerely,
>> Huq
>> On Fri, Jun 5, 2020 at 12:53 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Jun 5, 2020 at 12:32 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>> Input string:
>>>> mpiexec -np 1 ./poisson_m -n 10000000 -pc_type cholesky  -ksp_view
>>>> -ksp_converged_reason -ksp_monitor_true_residual
>>>> Output is attached herewith.
>>> Solving the problem...
>>>   0 KSP preconditioned resid norm 9.741453255800e+07 true resid norm
>>> 1.802775638200e+01 ||r(i)||/||b|| 1.000000000000e+00
>>>   1 KSP preconditioned resid norm 5.796040438920e+00 true resid norm
>>> 3.146946078273e-05 ||r(i)||/||b|| 1.745611606675e-06
>>> Your Cholesky preconditioner is crap, probably because the system is
>>> either not symmetric or nearly singular. You can see this
>>> because the preconditioned residual is 6 orders of magnitude greater
>>> than the true residual. Also, if you want to evaluate convergence, you
>>> should probably use a lower tolerance like
>>>   -ksp_rtol 1e-10
>>>   Thanks,
>>>      Matt
>>> Thank you.
>>>> Sincerely,
>>>> Huq
>>>> On Fri, Jun 5, 2020 at 10:16 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Jun 5, 2020 at 11:04 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>> Hello All,
>>>>>> I'm trying to calculate the norm_2 error of a solution.
>>>>>> Here, vector s: Analytical solution
>>>>>>           vector x: Numerical solution
>>>>>> ierr = VecView(s,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>>>>> ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>>>>>  ierr = VecAXPY(x,-1.0,s);CHKERRQ(ierr);
>>>>>>  ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
>>>>>>  ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
>>>>>>  if (norm > tol) {
>>>>>>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Second Norm of error %g\n",
>>>>>> double)norm);CHKERRQ(ierr);
>>>>>>     ierr = PetscPrintf(PETSC_COMM_WORLD,"Iterations
>>>>>> %D\n",its);CHKERRQ(ierr);
>>>>>> Am I calculating the "Norm_2" error correctly or making any mistake?
>>>>>> Unfortunately, for large sized matrix, say 10^6, I am getting very
>>>>>> high value of "Norm_2" error.
>>>>> 1) I am guessing x comes from a KSPSolve(). It is only as accurate as
>>>>> your tolerance
>>>>> 2) This is the l_2 norm, not the L_2 norm, so if you are using a
>>>>> continuum method like FEM, this is likely wrong.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thank you.
>>>>>> Sincerely,
>>>>>> Huq
>>>>>> Fazlul Huq
>>>>>> Graduate Research Assistant
>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>> E-mail: huq2090 at gmail.com
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Fazlul Huq
>>> experiments lead.
>>> -- Norbert Wiener
>> Fazlul Huq
> experiments lead.
> -- Norbert Wiener
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/3ae4b3ea/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/3ae4b3ea/attachment-0001.bin>
