[petsc-users] Norm_2 calculation
Matthew Knepley
knepley at gmail.com
Fri Jun 5 13:52:49 CDT 2020
On Fri, Jun 5, 2020 at 2:18 PM Fazlul Huq <huq2090 at gmail.com> wrote:
> The same is happening with "-pc_type hypre -pc_hypre_type boomerang" and
> with "-pc_type ilu".
> I tried with,
> ierr =
> KSPSetTolerances(ksp,1.e-10,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
> this also.
> Getting higher values of error even then.
Always check with
-pc_type lu
It seems likely that your matrix is flawed.
Matt
> Any suggestion to go over this issue?
> Shall I send the code? It's not a large script (single routine, less than
> 100 lines except comment).
> Thank you.
> Sincerely,
> Huq
> On Fri, Jun 5, 2020 at 12:53 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jun 5, 2020 at 12:32 PM Fazlul Huq <huq2090 at gmail.com> wrote:
>>> Input string:
>>> mpiexec -np 1 ./poisson_m -n 10000000 -pc_type cholesky -ksp_view
>>> -ksp_converged_reason -ksp_monitor_true_residual
>>> Output is attached herewith.
>> Solving the problem...
>> 0 KSP preconditioned resid norm 9.741453255800e+07 true resid norm
>> 1.802775638200e+01 ||r(i)||/||b|| 1.000000000000e+00
>> 1 KSP preconditioned resid norm 5.796040438920e+00 true resid norm
>> 3.146946078273e-05 ||r(i)||/||b|| 1.745611606675e-06
>> Your Cholesky preconditioner is crap, probably because the system is
>> either not symmetric or nearly singular. You can see this
>> because the preconditioned residual is 6 orders of magnitude greater than
>> the true residual. Also, if you want to evaluate convergence, you
>> should probably use a lower tolerance like
>> -ksp_rtol 1e-10
>> Thanks,
>> Matt
>> Thank you.
>>> Sincerely,
>>> Huq
>>> On Fri, Jun 5, 2020 at 10:16 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jun 5, 2020 at 11:04 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>> Hello All,
>>>>> I'm trying to calculate the norm_2 error of a solution.
>>>>> Here, vector s: Analytical solution
>>>>> vector x: Numerical solution
>>>>> ierr = VecView(s,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>>>> ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>>>> ierr = VecAXPY(x,-1.0,s);CHKERRQ(ierr);
>>>>> ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
>>>>> ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
>>>>> if (norm > tol) {
>>>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"Second Norm of error %g\n",
>>>>> double)norm);CHKERRQ(ierr);
>>>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"Iterations
>>>>> %D\n",its);CHKERRQ(ierr);
>>>>> Am I calculating the "Norm_2" error correctly or making any mistake?
>>>>> Unfortunately, for large sized matrix, say 10^6, I am getting very
>>>>> high value of "Norm_2" error.
>>>> 1) I am guessing x comes from a KSPSolve(). It is only as accurate as
>>>> your tolerance
>>>> 2) This is the l_2 norm, not the L_2 norm, so if you are using a
>>>> continuum method like FEM, this is likely wrong.
>>>> Thanks,
>>>> Matt
>>>>> Thank you.
>>>>> Sincerely,
>>>>> Huq
>>>>> Fazlul Huq
>>>>> Graduate Research Assistant
>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>> E-mail: huq2090 at gmail.com
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> Fazlul Huq
>> experiments lead.
>> -- Norbert Wiener
> Fazlul Huq
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/542274d1/attachment.html>
