[petsc-users] KSP not converge when turn on ksp_monitor_true_residual
Matthew Knepley
knepley at gmail.com
Fri Jun 5 10:13:32 CDT 2020
On Fri, Jun 5, 2020 at 10:17 AM Y. Shidi <ys453 at cam.ac.uk> wrote:
> Thank you for your reply.
> I set the relative tolerance of 1e-10, below is the output with
> ksp_monitor_true_residual,
> step 1 (converged):
> 0 KSP unpreconditioned resid norm 5.853072011788e-01 true resid norm
> 5.853072011788e-01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP unpreconditioned resid norm 1.263467051263e-02 true resid norm
> 1.263467051263e-02 ||r(i)||/||b|| 2.158639170539e-02
> 2 KSP unpreconditioned resid norm 1.341051880494e-03 true resid norm
> 1.341051880494e-03 ||r(i)||/||b|| 2.291193202122e-03
> 3 KSP unpreconditioned resid norm 5.281711107599e-04 true resid norm
> 5.281711107599e-04 ||r(i)||/||b|| 9.023827311473e-04
> 4 KSP unpreconditioned resid norm 2.265161267248e-04 true resid norm
> 2.265161267248e-04 ||r(i)||/||b|| 3.870038268256e-04
> 5 KSP unpreconditioned resid norm 6.083108409953e-05 true resid norm
> 6.083108409954e-05 ||r(i)||/||b|| 1.039301822650e-04
> 6 KSP unpreconditioned resid norm 2.049038801905e-05 true resid norm
> 2.049038801906e-05 ||r(i)||/||b|| 3.500792058903e-05
> 7 KSP unpreconditioned resid norm 4.908575378578e-06 true resid norm
> 4.908575378575e-06 ||r(i)||/||b|| 8.386323231099e-06
> 8 KSP unpreconditioned resid norm 1.160371295964e-06 true resid norm
> 1.160371295960e-06 ||r(i)||/||b|| 1.982499606399e-06
> 9 KSP unpreconditioned resid norm 2.993349323170e-07 true resid norm
> 2.993349323154e-07 ||r(i)||/||b|| 5.114150854671e-07
> 10 KSP unpreconditioned resid norm 6.423860393220e-08 true resid norm
> 6.423860392241e-08 ||r(i)||/||b|| 1.097519452913e-07
> 11 KSP unpreconditioned resid norm 1.486343352971e-08 true resid norm
> 1.486343352542e-08 ||r(i)||/||b|| 2.539424339131e-08
> 12 KSP unpreconditioned resid norm 3.388518888745e-09 true resid norm
> 3.388518889406e-09 ||r(i)||/||b|| 5.789299845588e-09
> 13 KSP unpreconditioned resid norm 8.414456498118e-10 true resid norm
> 8.414456551004e-10 ||r(i)||/||b|| 1.437613706795e-09
> 14 KSP unpreconditioned resid norm 2.052670281766e-10 true resid norm
> 2.052670332352e-10 ||r(i)||/||b|| 3.506996545092e-10
> 15 KSP unpreconditioned resid norm 4.739342260680e-11 true resid norm
> 4.739342219912e-11 ||r(i)||/||b|| 8.097187614243e-11
> Linear solve converged due to CONVERGED_RTOL iterations 15
> KSP Object: 1 MPI processes
> type: fgmres
> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, nonzero initial guess
> tolerances: relative=1e-10, absolute=1e-50, divergence=10000.
> right preconditioning
> using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: fieldsplit
> FieldSplit with Schur preconditioner, factorization FULL
> Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses A00's diagonal's inverse
> Split info:
> Split number 0 Defined by IS
> Split number 1 Defined by IS
> KSP solver for A00 block
> KSP Object: (fieldsplit_0_) 1 MPI processes
> type: preonly
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using NONE norm type for convergence test
> PC Object: (fieldsplit_0_) 1 MPI processes
> type: hypre
> HYPRE BoomerAMG preconditioning
> Cycle type V
> Maximum number of levels 25
> Maximum number of iterations PER hypre call 1
> Convergence tolerance PER hypre call 0.
> Threshold for strong coupling 0.25
> Interpolation truncation factor 0.
> Interpolation: max elements per row 0
> Number of levels of aggressive coarsening 0
> Number of paths for aggressive coarsening 1
> Maximum row sums 0.9
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Relax down symmetric-SOR/Jacobi
> Relax up symmetric-SOR/Jacobi
> Relax on coarse Gaussian-elimination
> Relax weight (all) 1.
> Outer relax weight (all) 1.
> Using CF-relaxation
> Not using more complex smoothers.
> Measure type local
> Coarsen type Falgout
> Interpolation type classical
> linear system matrix = precond matrix:
> Mat Object: (fieldsplit_0_) 1 MPI processes
> type: seqaij
> rows=28578, cols=28578
> total: nonzeros=653916, allocated nonzeros=653916
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> KSP solver for S = A11 - A10 inv(A00) A01
> KSP Object: (fieldsplit_1_) 1 MPI processes
> type: preonly
> PC Object: (fieldsplit_1_) 1 MPI processes
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> linear system matrix followed by preconditioner matrix:
> Mat Object: (fieldsplit_1_) 1 MPI processes
> type: schurcomplement
> rows=3874, cols=3874
> Schur complement A11 - A10 inv(A00) A01
> A11
> type: seqaij
> total: nonzeros=0, allocated nonzeros=0
> =0
> using I-node routines: found 775 nodes, limit used is
> 5
> A10
> Mat Object: 1 MPI processes
> type: seqaij
> rows=3874, cols=28578
> total: nonzeros=138180, allocated nonzeros=138180
> =0
> KSP of A00
> type: preonly
> divergence=10000.
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> =0
> A01
> type: seqaij
> rows=28578, cols=3874
> =0
> type: seqaij
> total: nonzeros=77704, allocated nonzeros=77704
> type: nest
> rows=32452, cols=32452
> Matrix object:
> type=nest, rows=2, cols=2
> MatNest structure:
> (0,0) : prefix="fieldsplit_0_", type=seqaij, rows=28578,
> cols=28578
> (0,1) : type=seqaij, rows=28578, cols=3874
> (1,0) : type=seqaij, rows=3874, cols=28578
> (1,1) : prefix="fieldsplit_1_", type=seqaij, rows=3874,
> cols=3874
> step 2 (NOT converged):
> Linear solve did not converge due to DIVERGED_NANORINF iterations 0
It looks like your matrix is invalid.
Matt
> type: fgmres
> type: fieldsplit
> Split info:
> type: preonly
> using DEFAULT norm type for convergence test
> type: hypre
> PC has not been set up so information may be incomplete
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> type: preonly
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> A11
> type: seqaij
> =0
> 5
> A10
> type: seqaij
> =0
> KSP of A00
> type: preonly
> divergence=10000.
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> =0
> A01
> type: seqaij
> =0
> type: seqaij
> type: nest
> Matrix object:
> MatNest structure:
> cols=28578
> cols=3874
> HOWEVER, if I do not use -ksp_monitor_true_residual, both two
> steps converge.
> step 1:
> type: fgmres
> type: fieldsplit
> Split info:
> type: preonly
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> type: preonly
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> A11
> type: seqaij
> =0
> 5
> A10
> type: seqaij
> =0
> KSP of A00
> type: preonly
> divergence=10000.
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> =0
> A01
> type: seqaij
> =0
> type: seqaij
> type: nest
> Matrix object:
> MatNest structure:
> cols=28578
> cols=3874
> step 2:
> type: fgmres
> type: fieldsplit
> Split info:
> type: preonly
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> type: preonly
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> A11
> type: seqaij
> =0
> 5
> A10
> type: seqaij
> =0
> KSP of A00
> type: preonly
> divergence=10000.
> type: hypre
> Cycle type V
> Sweeps down 1
> Sweeps up 1
> Sweeps on coarse 1
> Using CF-relaxation
> Measure type local
> type: seqaij
> =0
> A01
> type: seqaij
> =0
> type: seqaij
> type: nest
> Matrix object:
> MatNest structure:
> cols=28578
> cols=3874
> Thank you for your help and time.
> Kind regards,
> Shidi
> On 2020-06-05 13:40, Matthew Knepley wrote:
> > On Fri, Jun 5, 2020 at 7:42 AM Y. Shidi <ys453 at cam.ac.uk> wrote:
> >>> This algebraic tolerance is strange. Why put it below unit
> >> roundoff?
> >> We are testing a static bubble problem, if the tolerance is 1e-10 it
> >> won't approach static solution.
> > I do not understand. Every computation in your problem makes errors of
> > order 1e-15,
> > since that is the roundoff. Moreover, you cannot expect a solution to
> > be more accurate
> > than (condition number * roundoff). I would be surprised if the
> > condition number is near 1,
> > since you would not need a solver. So what is going on?
> > Thanks,
> > Matt
> >> Thanks,
> >> Shidi
> >> On 2020-06-05 11:48, Matthew Knepley wrote:
> >>> On Fri, Jun 5, 2020 at 6:12 AM Y. Shidi <ys453 at cam.ac.uk> wrote:
> >>>> Dear developers,
> >>>> We are using filed splitting method solve saddle point problem.
> >>>> Below is our ksp configuration:
> >>>> PetscOptionsSetValue(NULL,"-ksp_type","gmres");
> >>>> PetscOptionsSetValue(NULL,"-ksp_initial_guess_nonzero","");
> >>>> PetscOptionsSetValue(NULL,"-ksp_rtol","1e-20");
> >> roundoff?
> >>>> PetscOptionsSetValue(NULL,"-ksp_converged_reason", "");
> >>>> PetscOptionsSetValue(NULL,"-pc_type", "fieldsplit");
> >>>> PetscOptionsSetValue(NULL,"-pc_fieldsplit_type", "schur");
> >>>> PetscOptionsSetValue(NULL,"-pc_fieldsplit_schur_fact_type",
> >>>> "lower");
> >>>> PetscOptionsSetValue(NULL,"-pc_fieldsplit_schur_precondition",
> >>>> "selfp");
> >>>> PetscOptionsSetValue(NULL,"-fieldsplit_0_ksp_type", "preonly");
> >>>> PetscOptionsSetValue(NULL,"-fieldsplit_0_pc_type", "hypre");
> >>>> PetscOptionsSetValue(NULL,"-fieldsplit_1_ksp_type", "preonly");
> >>>> PetscOptionsSetValue(NULL,"-fieldsplit_1_pc_type", "hypre");
> >>>> It can be converged. However, when we turn on the ksp monitor:
> >>>> PetscOptionsSetValue(NULL,"-ksp_monitor_true_residual", "");
> >>>> It won't converge. It seems very odd, I am wondering why it
> >> happens.
> >>> Can you try it with a relative tolerance of 1e-10, and send the
> >> output
> >>> (with -ksp_view as well).
> >>> Thanks,
> >>> Matt
> >>>> Thank you for your time and help.
> >>>> Kind regards,
> >>>> Shidi
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to
> >> which
> >>> their experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/ [1]
> >>> Links:
> >>> [1] http://www.cse.buffalo.edu/~knepley/
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > Links:
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/6d1bf85b/attachment-0001.html>
