[petsc-users] Question on reverse scatters from VecScatterCreateToAll
Dave May
dave.mayhem23 at gmail.com
Fri Jun 5 07:04:52 CDT 2020
On Fri 5. Jun 2020 at 13:52, Fabian Jakub <
Fabian.Jakub at physik.uni-muenchen.de> wrote:
> Dear Petsc list,
> I have a question regarding reverse vec-scatters:
> I have a shared memory solver that I want to use on a distributed DMDA and
> average its results.
> The shared mem solver needs some of the global state.
> So I want to create a full copy of a global vec on each master rank of a
> machine, compute some result
> and average the results back into the global vec.
> For example: the parallel layout for a global vector is
> 3 ranks in comm_world, each with Ndof = 6, so global size is 18
> Then I create a mpi sub communicator with MPI_COMM_TYPE_SHARED
> Then I create a local vec on each rank, with sizes 9 on each rank_0 on the
> sub comm, size 0 otherwise
> if ( sub_id == 0 ) then
> call VecGetSize(gvec, Nlocal, ierr); call CHKERR(ierr)
> else
> Nlocal = 0
> endif
> call VecCreateSeq(PETSC_COMM_SELF, Nlocal, lvec, ierr)
> This yields for example (first 2 ranks in a shared mem subcomm, 3rd rank
> on another machine):
> Global rank_id | sub_rank_id | local_size_gvec | local_size_lvec
> 0 | 0 |
> 6 | 18
> 1 | 1 |
> 6 | 0
> 2 | 0 |
> 6 | 18
> To copy the global vec on each shared mem master, I do:
> ISCreateStride(PETSC_COMM_SELF, Nlocal, 0, 1, is, ierr)
> VecScatterCreate(gvec, is, lvec, is, ctx, ierr)
> VecScatterBegin(ctx, gvec, lvec, INSERT_VALUES, SCATTER_FORWARD, ierr)
> VecScatterEnd (ctx, gvec, lvec, INSERT_VALUES, SCATTER_FORWARD, ierr)
> That works fine.
> Then I want to do the reverse, i.e. add all values from the local vec to
> the global vec on comm_world to generate the average of the results.
> I tried:
> VecSet(gvec, zero, ierr)
> VecScatterBegin(ctx, gvec, lvec, ADD_VALUES, SCATTER_REVERSE, ierr)
> I was hoping to get the sum of svec in the global vec, so that gvec /
> comm_size(sub_comm_id==0) gives the mean.
> However, I get the following error:
> Nonconforming object sizes
> Vector wrong size 18 for scatter 6 (scatter reverse and vector to != ctx
> from size)
> Going with the same approach with VecScatterCreateToAll
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecScatterCreateToAll.html#VecScatterCreateToAll>
> leads to the same issue.
> Do you have suggestions on how I could/should achieve it?
You have to flip the lvec, gvec args in reverse mode (as per the man pages
states under Notes)
Thanks
Dave
> Many thanks!
> Fabian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200605/81e69f8c/attachment-0001.html>
