[petsc-users] Running example problem
Thu Jun 4 12:27:06 CDT 2020
Should work
If it fails -  send us corresponding configure.log
Satish
On Thu, 4 Jun 2020, Fazlul Huq wrote:
> I think it's okay to have a separate version of hypre for PETSc.
> So, what I understand is I have to do,
> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-mpich --download-fblaslapack --download-hypre
> make all test
> Is that all?
> Am I missing something?
> Thank you.
> Sincerely,
> Huq
> On Thu, Jun 4, 2020 at 11:04 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > Its best to use --download-hypre with PETSc configure - it installs a
> > compatible version of hypre.
> > If you have a pre-installed hypre, you'l have to:
> > - make sure its compatible version
> > - its built with the same MPI, compilers etc as PETSc
> > - you can use --with-hypre-dir option with PETSc configure
> > Satish
> > > I have HYPRE installed in my machine.
> > > Ithink, I need to compile PETSc with HYPRE.
> > > I'm not clear about how to do that?
> > > Thank you.
> > > Sincerely,
> > > Huq
> > > On Thu, Jun 4, 2020 at 10:13 AM Matthew Knepley <knepley at gmail.com>
> > wrote:
> > > > On Thu, Jun 4, 2020 at 10:28 AM Fazlul Huq <huq2090 at gmail.com> wrote:
> > > >> Thank you.
> > > >> Working now.
> > > >> I think to run the following command I need to configure PETSc with
> > HYPRE.
> > > >> mpiexec -np 1 ./poisson_m -n 100000 -pc_type hypre -pc_hypre_type
> > > >> boomerang
> > > >> If I am right, can you please guide me how to configure with HYPRE and
> > > >> run the above command?
> > > > --download-hypre
> > > >   Thanks,
> > > >      Matt
> > > >> Thank you.
> > > >> Sincerely,
> > > >> Huq
> > > >> On Thu, Jun 4, 2020 at 8:34 AM Matthew Knepley <knepley at gmail.com>
> > wrote:
> > > >>> On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com>
> > wrote:
> > > >>>> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com>
> > wrote:
> > > >>>>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com>
> > > >>>>> wrote:
> > > >>>>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com>
> > wrote:
> > > >>>>>>> Somehow, make is not working.
> > > >>>>>>> Please find the attachment herewith for the terminal readout.
> > > >>>>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
> > > >>>>>> environment.
> > > >>>>> Or just do
> > > >>>>> make ex5 PETSC_ARCH=linux-gnu
> > > >>>> sorry I hit send without checking your png)
> > > >>>> The command should be
> > > >>>> make ex5 PETSC_ARCH=arch-linux2-c-debug
> > > >>> No, your first one was right.
> > > >>>    Matt
> > > >>>>>>   Thanks,
> > > >>>>>>      Matt
> > > >>>>>>> Thank you.
> > > >>>>>>> Sincerely,
> > > >>>>>>> Huq
> > > >>>>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <
> > > >>>>>>> wrote:
> > > >>>>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com>
> > > >>>>>>>> wrote:
> > > >>>>>>>>> Hello,
> > > >>>>>>>>> I have a very preliminary question!
> > > >>>>>>>>> I think I have installed PETSc correctly cause I got following
> > on
> > > >>>>>>>>> the terminal:
> > > >>>>>>>>> Command:
> > > >>>>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu
> > > >>>>>>>>> check
> > > >>>>>>>>> Response:
> > > >>>>>>>>> Running check examples to verify correct installation
> > > >>>>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and
> > > >>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1
> > MPI
> > > >>>>>>>>> process
> > > >>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2
> > MPI
> > > >>>>>>>>> processes
> > > >>>>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1
> > > >>>>>>>>> MPI process
> > > >>>>>>>>> Completed test examples
> > > >>>>>>>>> Now, I am trying to run an example from the list of provided
> > > >>>>>>>>> examples.
> > > >>>>>>>>> Can you please help me out, how to run an example problem from
> > the
> > > >>>>>>>>> list of examples?
> > > >>>>>>>>> I mean, how to make executable and run the executable?
> > > >>>>>>>> cd $PETSC_DIR
> > > >>>>>>>> cd src/snes/tutorials
> > > >>>>>>>> make ex5
> > > >>>>>>>> ./ex5 -snes_monitor
> > > >>>>>>>>   Thanks,
> > > >>>>>>>>      Matt
> > > >>>>>>>>> Thank you.
> > > >>>>>>>>> Sincerely,
> > > >>>>>>>>> Huq
> > > >>>>>>>>> Fazlul Huq
> > > >>>>>>>>> Graduate Research Assistant
> > > >>>>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> > > >>>>>>>>> University of Illinois at Urbana-Champaign (UIUC)
> > > >>>>>>>>> E-mail: huq2090 at gmail.com
> > > >>>>>>>> What most experimenters take for granted before they begin their
> > > >>>>>>>> experiments is infinitely more interesting than any results to
> > which their
> > > >>>>>>>> experiments lead.
> > > >>>>>>>> -- Norbert Wiener
> > > >>>>>>>> https://www.cse.buffalo.edu/~knepley/
> > > >>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
> > > >>>>>>> Fazlul Huq
> > which their
> > > >>>>>> experiments lead.
> > > >>>>>> -- Norbert Wiener
> > > >>> experiments is infinitely more interesting than any results to which
> > their
> > > >>> experiments lead.
> > > >>> -- Norbert Wiener
> > > >> Fazlul Huq
> > their
> > > > experiments lead.
> > > > -- Norbert Wiener
