[petsc-users] Configuration error during OpenBLAS
Eda Oktay
eda.oktay at metu.edu.tr
Fri Jul 31 02:23:49 CDT 2020
Dear Satish,
Thank you so much for your replies. I installed git and I was able to
configure PETSc.
Thanks again!
Eda
Satish Balay <balay at mcs.anl.gov>, 30 Tem 2020 Per, 18:32 tarihinde şunu yazdı:
> On Thu, 30 Jul 2020, Eda Oktay wrote:
> > Dear Satish,
> > I am sorry but I couldn't understand what should I do. Am I getting this
> > error because of case insensitivity?
> Its a bug in configure. I sent the fix [diff - 2 different fixes, you can try any one of them] in a different reply.
> > If I am, why now? I mean I configured Petsc with exact same options before
> > in 2 machines. What can be the reason?
> Likely you have git installed on the other 2 machines - so this issue didn't come up. Without git - a tarball gets used, this issue is with tarball usage.
> [or if don't have git on these machines as well - they likely have case insensitive file system - aka MacOS]
> Satish
