[petsc-users] Only print converged reason when not converged
Alexander Lindsay
alexlindsay239 at gmail.com
Thu Jul 30 11:14:58 CDT 2020
I like that a lot. I'll try to spin-up a PR (MR on gitlab?) today.
On Tue, Jul 28, 2020 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
> Yes, this is a good idea. Simple extension of current code.
> The command line would then be
> -snes_converged_reason ::failed
> add in petscviewer.h
> a new PetscViewerFormat PETSC_VIEWER_FAILED,
> add in viewera.c PetscViewerFormats FAILED.
> add in SNESReasonView
> if (snes->reason > 0 && format != PETSC_VIEWER_FAILED) {
> Document it in SNESReasonView manual page
> On Jul 28, 2020, at 7:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 28, 2020 at 8:09 PM Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> The only slight annoyance with doing this through a PostSolve hook as
>> opposed to a pluggable ReasonView system is that if a user passed
>> `-snes_converged_reason` on the command line, we would get redundant
>> printout from SNESSolve and our PostSolve. Although I suppose we could
>> solve this by intercepting their option, not passing it to PETSc, and then
>> just using that info to control the output from our PostSolve (e.g. if a
>> user passes -snes_converged_reason from the command line, then we should
>> always print the reason, instead of just printing when we don't converge).
>> So maybe the PostSolve will work fine.
> Can't you just define another ASCII format that prints what you want for
> ReasonView?
> Matt
>> On Tue, Jul 28, 2020 at 12:20 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> KPSSetPostSolve(), There is no SNESSetPostSolve() but there
>>> could/should be.
>>> Barry
>>> Note inside the SNESSolve there are a bunch of pre and post hooks,
>>> don't get the confused with an outside SNESSetPostSolve()
>>> On Jul 28, 2020, at 1:12 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>>> One alternative is to support a plugable KSP/SNESReasonView system. We
>>> then could hook up KSP/SNESReasonView_MOOSE.
>>> We could call our views from SNES/KSP"done"Solve as well if such a
>>> system is not affordable. What are the final functions we should call,
>>> where we guarantee SNES/KSP is already done?
>>> Thanks,
>>> Fande,
>>> On Tue, Jul 28, 2020 at 12:02 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> Alex,
>>>> The actual printing is done with SNESReasonView() and
>>>> KSPReasonView() I would suggest copying those files to Moose with a name
>>>> change and removing all the code you don't want. Then you can call your
>>>> versions immediately after SNESSolve() and KSPSolve().
>>>> Barry
>>>> > On Jul 28, 2020, at 10:43 AM, Alexander Lindsay <
>>>> > To help debug the many emails we get about solves that fail to
>>>> converge, in MOOSE we recently appended `-snes_converged_reason
>>>> -ksp_converged_reason` for every call to `SNESSolve`. Of course, now we
>>>> have users complaining about the new text printed to their screens that
>>>> they didn't have before. Some of them have made a reasonable request to
>>>> only print the convergence reason when the solve has actually failed to
>>>> converge. Is there some way we can only print the reason if we've diverged,
>>>> e.g. if reason < 0 ?
>>>> > Alex
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200730/9fd1f2bf/attachment.html>
