[petsc-users] SLEPc download error
Matthew Knepley
knepley at gmail.com
Mon Jul 27 19:08:14 CDT 2020
On Mon, Jul 27, 2020 at 6:50 PM Eda Oktay <eda.oktay at metu.edu.tr> wrote:
> Hi all,
> I am trying to download Petsc with Slepc a linux computer (probably
> ubuntu, I don't know because I am using it via ssh) but I am getting
> the following error:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> Error during download/extract/detection of SLEPC:
> Unable to download package SLEPC from:
> https://gitlab.com/slepc/slepc/-/archive/v3.13.2/slepc-v3.13.2.tar.gz
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
> * You can run with --with-packages-download-dir=/adirectory and
> ./configure will instruct you what packages to download manually
> * or you can download the above URL manually, to
> /yourselectedlocation/slepc-v3.13.2.tar.gz
> and use the configure option:
> --download-slepc=/yourselectedlocation/slepc-v3.13.2.tar.gz
> I attached configure.log.
> Then, I downloaded slepc and used
> --download-slepc=/yourselectedlocation/slepc-v3.13.2.tar.gz.
> Since I used WinSCP, tar.gz file was uploaded to my user as "eda" and
> I used --download-slepc=/home/eda/eda and ran configure again.
> However, I got the following error:
> for details):
> Unknown compression type in URL: file:///home/eda/eda
> I also attached this confiigure.log as 2configure.log.
> When I tried to untar eda, I could and I got slepc. So I don't
> understand why I am getting this error. This is the third computer I
> am building Petsc with Slepc but this is the first time I am getting
> such an error.
> Can you help me with this problem?
Rename your downloaded file to have the .tar.gz suffix.
Matt
> Thanks!
> Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200727/50dd3b05/attachment.html>
