[petsc-users] SLEPc download error
Eda Oktay eda.oktay at metu.edu.tr
Mon Jul 27 17:49:15 CDT 2020
Hi all,
I am trying to download Petsc with Slepc a linux computer (probably
ubuntu, I don't know because I am using it via ssh) but I am getting
the following error:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Error during download/extract/detection of SLEPC:
Unable to download package SLEPC from:
https://gitlab.com/slepc/slepc/-/archive/v3.13.2/slepc-v3.13.2.tar.gz
* If URL specified manually - perhaps there is a typo?
* If your network is disconnected - please reconnect and rerun ./configure
* Or perhaps you have a firewall blocking the download
* You can run with --with-packages-download-dir=/adirectory and
./configure will instruct you what packages to download manually
* or you can download the above URL manually, to
/yourselectedlocation/slepc-v3.13.2.tar.gz
  and use the configure option:
  --download-slepc=/yourselectedlocation/slepc-v3.13.2.tar.gz
I attached configure.log.
Then, I downloaded slepc and used
--download-slepc=/yourselectedlocation/slepc-v3.13.2.tar.gz.
Since I used WinSCP, tar.gz file was uploaded to my user as "eda" and
I used   --download-slepc=/home/eda/eda and ran configure again.
However, I got the following error:
for details):
Unknown compression type in URL: file:///home/eda/eda
I also attached this confiigure.log as 2configure.log.
When I tried to untar eda, I could and I got slepc. So I don't
understand why I am getting this error. This is the third computer I
am building Petsc with Slepc but this is the first time I am getting
such an error.
Can you help me with this problem?
Thanks!
Eda
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/2f67c65a/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/2f67c65a/attachment-0003.obj>
