[petsc-users] SUPERLU_DIST in single precision
flw at rzg.mpg.de
flw at rzg.mpg.de
Mon Jul 27 14:10:54 CDT 2020
Hi Shery,
Yes, ideally we would like to compile PETSc in single precision and
simply run a single precision version of SUPERLU_DIST just like e.g.
MUMPS.
Best regards and thanks,
Felix
Zitat von "Xiaoye S. Li" <xsli at lbl.gov>:
> Barry,
> I have a branch 'Mixed-precision' working with single precision FP32. I
> assume Felix wants to use superlu_dist from petsc. How do you want to
> incorporate it in petsc?
> https://github.com/xiaoyeli/superlu_dist
> PS1: in this version, FP32 only works on CPU. FP64 and complex-FP64 all
> work on GPU.
> PS2: currently there is no mixed-precision yet, but it is the branch we are
> adding mix-prec support. Will take a while before merging to master.
> Sherry
> On Wed, Jul 22, 2020 at 6:04 AM <flw at rzg.mpg.de> wrote:
>> Hi Barry,
>> for now I just want to run everything in single on CPUs only with
>> SUPERLU_DIST. Maybe we will also incorporate GPUs in the future, but
>> there are no immediate plans yet. So if you could provide the support,
>> that would be awesome.
>> Best regards,
>> Felix
>> Zitat von Barry Smith <bsmith at petsc.dev>:
>> > Felix,
>> > What are your needs, do you want this for CPUs or for GPUs? Do
>> > you wish to run all your code in single precision or just the
>> > SuperLU_Dist solver while the rest of your code double?
>> > If you want to run everything on CPUs using single precision
>> > then adding the support is very easy, we can provide that for you
>> > any time. The other cases will require more thought.
>> > Barry
>> >> On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
>> >> Dear PETSc support team,
>> >> some time ago you told me that you are planning on releasing a
>> >> version that supports SUPERLU_DIST in single-precision soon. Can
>> >> you tell me roughly what time frame you had in mind?
>> >> Best regards,
>> >> Felix
