[petsc-users] SUPERLU_DIST in single precision
flw at rzg.mpg.de
flw at rzg.mpg.de
Thu Jul 23 03:02:05 CDT 2020
Hi Sherry,
thanks, that would be awesome!
Best regards,
Felix
Quoting "Xiaoye S. Li" <xsli at lbl.gov>:
> I can package a CPU version over the weekend.
> Sherry
> On Wed, Jul 22, 2020 at 6:04 AM <flw at rzg.mpg.de> wrote:
>> Hi Barry,
>> for now I just want to run everything in single on CPUs only with
>> SUPERLU_DIST. Maybe we will also incorporate GPUs in the future, but
>> there are no immediate plans yet. So if you could provide the support,
>> that would be awesome.
>> Best regards,
>> Felix
>> Zitat von Barry Smith <bsmith at petsc.dev>:
>> > Felix,
>> > What are your needs, do you want this for CPUs or for GPUs? Do
>> > you wish to run all your code in single precision or just the
>> > SuperLU_Dist solver while the rest of your code double?
>> > If you want to run everything on CPUs using single precision
>> > then adding the support is very easy, we can provide that for you
>> > any time. The other cases will require more thought.
>> > Barry
>> >> On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
>> >> Dear PETSc support team,
>> >> some time ago you told me that you are planning on releasing a
>> >> version that supports SUPERLU_DIST in single-precision soon. Can
>> >> you tell me roughly what time frame you had in mind?
>> >> Best regards,
>> >> Felix
