[petsc-users] Matrix assembly in SNES problem
    Adolfo Rodriguez
    adantra at gmail.com
    Wed Jul 22 09:35:56 CDT 2020
Hong,
Thanks for your email. My question now is how to handle situations where
the matrix structure changes during the iteration process?
Adolfo
On Wed, Jul 22, 2020 at 8:32 AM Zhang, Hong <hongzhang at anl.gov> wrote:
> > On Jul 22, 2020, at 7:03 AM, Adolfo Rodriguez <adantra at gmail.com> wrote:
> > I am trying to replace the non-linear solver in a flow simulation
> problem where the matrix sparsity can change during the iterations. I tried
> successfully to create the matrix within the FormJacobian function but I
> have a memory leak which I don't know how to fix.
> > My FormJacobian function is something like this:
> > .. FormJacobian( ..){
> >      matrixconstruction(); // returns csr matrix in c++ regular vectors
> >      MatSeqAIJSetPreallocationCSR ...;
> >      //loop over the entries and
> >      MatSetValues;
> >      MatAssemblyBegin();
> >      MatAssemblyEnd();
> >      return 0;
> Yes, the leak is caused by the new matrix created every time FormJacobian
> is called. The working matrix for SNES needs to be allocated only once and
> passed to SNES by using
> SNESSetJacobian(SNES snes,Mat Amat,Mat Pmat,PetscErrorCode
> (*J)(SNES,Vec,Mat,Mat,void*),void *ctx)
> In your FormJacobian(SNES snes,Vec x,Mat A,Mat B,void *ctx), you just need
> to copy the csr matrix to the matrix A, which has already been allocated.
> The working matrix should be destroyed after SNESSolve().
> Hong (Mr.)
> > This approach works for small problems but, when dealing with large ones
> I observe a memory leak. I am pretty sure that It is related to the fact
> that I am creating new matrices every time FormJacobian is called but I
> don't know how to destroy it between iterations.
> > Any suggestions?
> > Regards,
> > Adolfo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200722/f6be5216/attachment-0001.html>
