[petsc-users] Matrix assembly in SNES problem
Matthew Knepley
knepley at gmail.com
Wed Jul 22 09:30:56 CDT 2020
On Wed, Jul 22, 2020 at 9:32 AM Zhang, Hong via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> > On Jul 22, 2020, at 7:03 AM, Adolfo Rodriguez <adantra at gmail.com> wrote:
> > I am trying to replace the non-linear solver in a flow simulation
> problem where the matrix sparsity can change during the iterations. I tried
> successfully to create the matrix within the FormJacobian function but I
> have a memory leak which I don't know how to fix.
> > My FormJacobian function is something like this:
> > .. FormJacobian( ..){
> > matrixconstruction(); // returns csr matrix in c++ regular vectors
> > MatSeqAIJSetPreallocationCSR ...;
> > //loop over the entries and
> > MatSetValues;
> > MatAssemblyBegin();
> > MatAssemblyEnd();
> > return 0;
> Yes, the leak is caused by the new matrix created every time FormJacobian
> is called. The working matrix for SNES needs to be allocated only once and
> passed to SNES by using
> SNESSetJacobian(SNES snes,Mat Amat,Mat Pmat,PetscErrorCode
> (*J)(SNES,Vec,Mat,Mat,void*),void *ctx)
> In your FormJacobian(SNES snes,Vec x,Mat A,Mat B,void *ctx), you just need
> to copy the csr matrix to the matrix A, which has already been allocated.
> The working matrix should be destroyed after SNESSolve().
Hong, what is the best way to wipe out the existing structure, preallocate,
and set new values?
Matt
> Hong (Mr.)
> > This approach works for small problems but, when dealing with large ones
> I observe a memory leak. I am pretty sure that It is related to the fact
> that I am creating new matrices every time FormJacobian is called but I
> don't know how to destroy it between iterations.
> > Any suggestions?
> > Regards,
> > Adolfo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200722/e58d5e84/attachment.html>
