[petsc-users] Error on INTEGER SIZE using DMDACreate3d
Mark Adams
mfadams at lbl.gov
Tue Jul 21 09:56:48 CDT 2020
On Tue, Jul 21, 2020 at 9:46 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 21, 2020 at 9:35 AM Pierpaolo Minelli <
> pierpaolo.minelli at cnr.it> wrote:
>> Thanks for your reply.
>> As I wrote before, I use these settings:
>> -dm_mat_type hypre -pc_type hypre -pc_hypre_type boomeramg
>> -pc_hypre_boomeramg_relax_type_all SOR/Jacobi
>> -pc_hypre_boomeramg_coarsen_type PMIS -pc_hypre_boomeramg_interp_type FF1
>> -ksp_type richardson
>> Is there a way to emulate this features also with GAMG?
> Smoothers: You have complete control here
> -mg_levels_pc_type sor (the default is Chebyshev which you could also
> try)
And you set the KSP type. You have -ksp_type richardson above but that is
not used for Hypre. It is for GAMG. Chebyshev is a ksp type (-ksp_type
chebyshev).
Hypre is very good on Poisson. THe grid complexity (cost per iteration) can
be high but the convergence rate will be better than GAMG.
But, you should be able to get hypre to work.
> Coarsening: This is much different in agglomeration AMG. There is a
> discussion here:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetSquareGraph.html
> Interpolation: This is built-in for agglomeration AMG.
>> It would be better to use only native Petsc implementations, but these
>> settings, up to single precision indexing for integers, gave me optimal
>> performances.
>> For this reason I asked also, if it was possible to configure hypre
>> (inside Petsc) with 64bit integers.
> Yes. That happened when you reconfigured for 64 bits. You may have
> encountered a Hypre bug.
> Thanks,
> Matt
>> Pierpaolo
>> Il giorno 21 lug 2020, alle ore 13:36, Dave May <dave.mayhem23 at gmail.com>
>> ha scritto:
>> On Tue, 21 Jul 2020 at 12:32, Pierpaolo Minelli <pierpaolo.minelli at cnr.it>
>> wrote:
>>> Hi,
>>> I have asked to compile a Petsc Version updated and with 64bit indices.
>>> Now I have Version 3.13.3 and these are the configure options used:
>>> #!/bin/python
>>> if __name__ == '__main__':
>>> import sys
>>> import os
>>> sys.path.insert(0, os.path.abspath('config'))
>>> import configure
>>> configure_options = [
>>> '--CC=mpiicc',
>>> '--CXX=mpiicpc',
>>> '--download-hypre',
>>> '--download-metis',
>>> '--download-mumps=yes',
>>> '--download-parmetis',
>>> '--download-scalapack',
>>> '--download-superlu_dist',
>>> '--known-64-bit-blas-indices',
>>> '--prefix=/cineca/prod/opt/libraries/petsc/3.13.3_int64/intelmpi--2018--binary',
>>> '--with-64-bit-indices=1',
>>> '--with-blaslapack-dir=/cineca/prod/opt/compilers/intel/pe-xe-2018/binary/mkl',
>>> '--with-cmake-dir=/cineca/prod/opt/tools/cmake/3.12.0/none',
>>> '--with-debugging=0',
>>> '--with-fortran-interfaces=1',
>>> '--with-fortran=1',
>>> 'FC=mpiifort',
>>> 'PETSC_ARCH=arch-linux2-c-opt',
>>> configure.petsc_configure(configure_options)
>>> Now, I receive an error on hypre:
>>> forrtl: error (78): process killed (SIGTERM)
>>> Image PC Routine Line
>>> Source
>>> libHYPRE-2.18.2.s 00002B33CF465D3F for__signal_handl
>>> Unknown Unknown
>>> libpthread-2.17.s 00002B33D5BFD370 Unknown
>>> Unknown Unknown
>>> libpthread-2.17.s 00002B33D5BF96D3 pthread_cond_wait
>>> Unknown Unknown
>>> libiomp5.so 00002B33DBA14E07 Unknown
>>> Unknown Unknown
>>> libiomp5.so 00002B33DB98810C Unknown
>>> Unknown Unknown
>>> libiomp5.so 00002B33DB990578 Unknown
>>> Unknown Unknown
>>> libiomp5.so 00002B33DB9D9659 Unknown
>>> Unknown Unknown
>>> libiomp5.so 00002B33DB9D8C39 Unknown
>>> Unknown Unknown
>>> libiomp5.so 00002B33DB993BCE __kmpc_fork_call
>>> Unknown Unknown
>>> PIC_3D 00000000004071C0 Unknown
>>> Unknown Unknown
>>> PIC_3D 0000000000490299 Unknown
>>> Unknown Unknown
>>> PIC_3D 0000000000492C17 Unknown
>>> Unknown Unknown
>>> PIC_3D 000000000040562E Unknown
>>> Unknown Unknown
>>> libc-2.17.so 00002B33DC5BEB35 __libc_start_main
>>> Unknown Unknown
>>> PIC_3D 0000000000405539 Unknown
>>> Unknown Unknown
>>> Is it possible that I need to ask also to compile hypre with an option
>>> for 64bit indices?
>>> Is it possible to instruct this inside Petsc configure?
>>> Alternatively, is it possible to use a different multigrid PC inside
>>> PETSc that accept 64bit indices?
>> You can use
>> -pc_type gamg
>> All native PETSc implementations support 64bit indices.
>>> Thanks in advance
>>> Pierpaolo
>>> Il giorno 27 mag 2020, alle ore 11:26, Stefano Zampini <
>>> stefano.zampini at gmail.com> ha scritto:
>>> You need a version of PETSc compiled with 64bit indices, since the
>>> message indicates the number of dofs in this case is larger the INT_MAX
>>> 2501×3401×1601 = 13617947501
>>> I also suggest you upgrade to a newer version, 3.8.3 is quite old as the
>>> error message reports
>>> Il giorno mer 27 mag 2020 alle ore 11:50 Pierpaolo Minelli <
>>> pierpaolo.minelli at cnr.it> ha scritto:
>>>> Hi,
>>>> I am trying to solve a Poisson equation on this grid:
>>>> Nx = 2501
>>>> Ny = 3401
>>>> Nz = 1601
>>>> I received this error:
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Overflow in integer operation:
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#64-bit-indices
>>>> [0]PETSC ERROR: Mesh of 2501 by 3401 by 1 (dof) is too large for 32 bit
>>>> indices
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
>>>> [0]PETSC ERROR:
>>>> /marconi_scratch/userexternal/pminelli/PIC3D/2500_3400_1600/./PIC_3D on a
>>>> arch-linux2-c-opt named r129c09s02 by pminelli Tu
>>>> e May 26 20:16:34 2020
>>>> [0]PETSC ERROR: Configure options
>>>> --prefix=/cineca/prod/opt/libraries/petsc/3.8.3/intelmpi--2018--binary
>>>> CC=mpiicc FC=mpiifort CXX=mpiicpc
>>>> F77=mpiifort F90=mpiifort --with-debugging=0
>>>> --with-fortran=1
>>>> --with-cmake-dir=/cineca/prod/opt/tools/cmake/3.5.2/none
>>>> --with-mpi-dir=/cineca/prod/opt/compilers/intel/pe-xe-
>>>> 2018/binary/impi/2018.4.274 --download-scalapack --download-mumps=yes
>>>> --download-hypre --download-superlu_dist --download-parmetis --downlo
>>>> ad-metis
>>>> [0]PETSC ERROR: #1 DMSetUp_DA_3D() line 218 in
>>>> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/
>>>> impls/da/da3.c
>>>> [0]PETSC ERROR: #2 DMSetUp_DA() line 25 in
>>>> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/impl
>>>> s/da/dareg.c
>>>> [0]PETSC ERROR: #3 DMSetUp() line 720 in
>>>> /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/interf
>>>> ace/dm.c
>>>> forrtl: error (76): Abort trap signal
>>>> I am on an HPC facility and after I loaded PETSC module, I have seen
>>>> that it is configured with INTEGER size = 32
>>>> I solve my problem with these options and it works perfectly with
>>>> smaller grids:
>>>> Is it possible to overcome this if I ask them to install a version with
>>>> INTEGER SIZE = 64?
>>>> Alternatively, is it possible to overcome this using intel compiler
>>>> options?
>>>> Thanks in advance
>>>> Pierpaolo Minelli
>>> Stefano
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200721/8441edf5/attachment.html>
