[petsc-users] Error on INTEGER SIZE using DMDACreate3d
Pierpaolo Minelli pierpaolo.minelli at cnr.it
Tue Jul 21 09:26:41 CDT 2020
Thanks for your useful suggestions.
Pierpaolo
> Il giorno 21 lug 2020, alle ore 15:45, Matthew Knepley <knepley at gmail.com> ha scritto:
> On Tue, Jul 21, 2020 at 9:35 AM Pierpaolo Minelli <pierpaolo.minelli at cnr.it <mailto:pierpaolo.minelli at cnr.it>> wrote:
> Thanks for your reply.
> As I wrote before, I use these settings:
> -dm_mat_type hypre -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_relax_type_all SOR/Jacobi -pc_hypre_boomeramg_coarsen_type PMIS -pc_hypre_boomeramg_interp_type FF1 -ksp_type richardson
> Is there a way to emulate this features also with GAMG?
> Smoothers: You have complete control here
>   -mg_levels_pc_type sor   (the default is Chebyshev which you could also try)
> Coarsening: This is much different in agglomeration AMG. There is a discussion here:
>   https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetThreshold.html>
>   https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetSquareGraph.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCGAMGSetSquareGraph.html>
> Interpolation: This is built-in for agglomeration AMG.
> It would be better to use only native Petsc implementations, but these settings, up to single precision indexing for integers, gave me optimal performances.
> For this reason I asked also, if it was possible to configure hypre (inside Petsc) with 64bit integers.
> Yes. That happened when you reconfigured for 64 bits. You may have encountered a Hypre bug.
>   Thanks,
>     Matt
> Pierpaolo
>> Il giorno 21 lug 2020, alle ore 13:36, Dave May <dave.mayhem23 at gmail.com <mailto:dave.mayhem23 at gmail.com>> ha scritto:
>> On Tue, 21 Jul 2020 at 12:32, Pierpaolo Minelli <pierpaolo.minelli at cnr.it <mailto:pierpaolo.minelli at cnr.it>> wrote:
>> Hi,
>> I have asked to compile a Petsc Version updated and with 64bit indices.
>> Now I have Version 3.13.3 and these are the configure options used:
>> #!/bin/python
>> if __name__ == '__main__':
>>   import sys
>>   import os
>>   sys.path.insert(0, os.path.abspath('config'))
>>   import configure
>>   configure_options = [
>>     '--CC=mpiicc',
>>     '--CXX=mpiicpc',
>>     '--download-hypre',
>>     '--download-metis',
>>     '--download-mumps=yes',
>>     '--download-parmetis',
>>     '--download-scalapack',
>>     '--download-superlu_dist',
>>     '--known-64-bit-blas-indices',
>>     '--prefix=/cineca/prod/opt/libraries/petsc/3.13.3_int64/intelmpi--2018--binary',
>>     '--with-64-bit-indices=1',
>>     '--with-blaslapack-dir=/cineca/prod/opt/compilers/intel/pe-xe-2018/binary/mkl',
>>     '--with-cmake-dir=/cineca/prod/opt/tools/cmake/3.12.0/none',
>>     '--with-debugging=0',
>>     '--with-fortran-interfaces=1',
>>     '--with-fortran=1',
>>     'FC=mpiifort',
>>     'PETSC_ARCH=arch-linux2-c-opt',
>>   configure.petsc_configure(configure_options)
>> Now, I receive an error on hypre:
>> forrtl: error (78): process killed (SIGTERM)
>> Image              PC                Routine            Line        Source
>> libHYPRE-2.18.2.s  00002B33CF465D3F  for__signal_handl     Unknown  Unknown
>> libpthread-2.17.s  00002B33D5BFD370  Unknown               Unknown  Unknown
>> libpthread-2.17.s  00002B33D5BF96D3  pthread_cond_wait     Unknown  Unknown
>> libiomp5.so        00002B33DBA14E07  Unknown               Unknown  Unknown
>> libiomp5.so        00002B33DB98810C  Unknown               Unknown  Unknown
>> libiomp5.so        00002B33DB990578  Unknown               Unknown  Unknown
>> libiomp5.so        00002B33DB9D9659  Unknown               Unknown  Unknown
>> libiomp5.so        00002B33DB9D8C39  Unknown               Unknown  Unknown
>> libiomp5.so        00002B33DB993BCE  __kmpc_fork_call      Unknown  Unknown
>> PIC_3D             00000000004071C0  Unknown               Unknown  Unknown
>> PIC_3D             0000000000490299  Unknown               Unknown  Unknown
>> PIC_3D             0000000000492C17  Unknown               Unknown  Unknown
>> PIC_3D             000000000040562E  Unknown               Unknown  Unknown
>> libc-2.17.so <http://libc-2.17.so/>       00002B33DC5BEB35  __libc_start_main     Unknown  Unknown
>> PIC_3D             0000000000405539  Unknown               Unknown  Unknown
>> Is it possible that I need to ask also to compile hypre with an option for 64bit indices?
>> Is it possible to instruct this inside Petsc configure?
>> Alternatively, is it possible to use a different multigrid PC inside PETSc that accept 64bit indices?
>> You can use
>>   -pc_type gamg
>> All native PETSc implementations support 64bit indices.
>> Thanks in advance
>> Pierpaolo
>>> Il giorno 27 mag 2020, alle ore 11:26, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> ha scritto:
>>> You need a version of PETSc compiled with 64bit indices, since the message indicates the number of dofs in this case is larger the INT_MAX
>>> 2501×3401×1601 = 13617947501
>>> I also suggest you upgrade to a newer version, 3.8.3 is quite old as the error message reports
>>> Il giorno mer 27 mag 2020 alle ore 11:50 Pierpaolo Minelli <pierpaolo.minelli at cnr.it <mailto:pierpaolo.minelli at cnr.it>> ha scritto:
>>> Hi,
>>> I am trying to solve a Poisson equation on this grid:
>>> Nx = 2501
>>> Ny = 3401
>>> Nz = 1601
>>> I received this error:
>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [0]PETSC ERROR: Overflow in integer operation: http://www.mcs.anl.gov/petsc/documentation/faq.html#64-bit-indices <http://www.mcs.anl.gov/petsc/documentation/faq.html#64-bit-indices>
>>> [0]PETSC ERROR: Mesh of 2501 by 3401 by 1 (dof) is too large for 32 bit indices
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.8.3, Dec, 09, 2017
>>> [0]PETSC ERROR: /marconi_scratch/userexternal/pminelli/PIC3D/2500_3400_1600/./PIC_3D on a arch-linux2-c-opt named r129c09s02 by pminelli Tu
>>> e May 26 20:16:34 2020
>>> [0]PETSC ERROR: Configure options --prefix=/cineca/prod/opt/libraries/petsc/3.8.3/intelmpi--2018--binary CC=mpiicc FC=mpiifort CXX=mpiicpc
>>> F77=mpiifort F90=mpiifort --with-debugging=0 --with-blaslapack-dir=/cineca/prod/opt/compilers/intel/pe-xe-2018/binary/mkl --with-fortran=1
>>> --with-fortran-interfaces=1 --with-cmake-dir=/cineca/prod/opt/tools/cmake/3.5.2/none --with-mpi-dir=/cineca/prod/opt/compilers/intel/pe-xe-
>>> 2018/binary/impi/2018.4.274 --download-scalapack --download-mumps=yes --download-hypre --download-superlu_dist --download-parmetis --downlo
>>> ad-metis
>>> [0]PETSC ERROR: #1 DMSetUp_DA_3D() line 218 in /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/
>>> impls/da/da3.c
>>> [0]PETSC ERROR: #2 DMSetUp_DA() line 25 in /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/impl
>>> s/da/dareg.c
>>> [0]PETSC ERROR: #3 DMSetUp() line 720 in /marconi/prod/build/libraries/petsc/3.8.3/intelmpi--2018--binary/BA_WORK/petsc-3.8.3/src/dm/interf
>>> ace/dm.c
>>> forrtl: error (76): Abort trap signal
>>> I am on an HPC facility and after I loaded PETSC module, I have seen that it is configured with INTEGER size = 32
>>> I solve my problem with these options and it works perfectly with smaller grids:
>>> Is it possible to overcome this if I ask them to install a version with INTEGER SIZE = 64?
>>> Alternatively, is it possible to overcome this using intel compiler options?
>>> Thanks in advance
>>> Pierpaolo Minelli
>>> Stefano
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200721/a9928bb9/attachment.html>
