[petsc-users] Tough to reproduce petsctablefind error
Fande Kong
fdkong.jd at gmail.com
Mon Jul 20 17:19:55 CDT 2020
On Mon, Jul 20, 2020 at 1:14 PM Mark Adams <mfadams at lbl.gov> wrote:
> This is indeed a nasty bug, but having two separate should be useful.
> Chris is using Haswell, what MPI are you using? I trust you are not using
> Moose.
> Fande what machine/MPI are you using?
#define PETSC_MPICC_SHOW
"/apps/local/spack/software/gcc-4.8.5/gcc-9.2.0-bxc7mvbmrfcrusa6ij7ux3exfqabmq5y/bin/gcc
-I/apps/local/mvapich2/2.3.3-gcc-9.2.0/include
-L/apps/local/mvapich2/2.3.3-gcc-9.2.0/lib -Wl,-rpath
-Wl,/apps/local/mvapich2/2.3.3-gcc-9.2.0/lib -Wl,--enable-new-dtags -lmpi"
I guess it is mvapich2-2.3.3.
Here is the machine configuration https://www.top500.org/system/179708/
BTW (if you missed my earlier posts), if I switch to MPT-MPI (a vendor
installed MPI), everything runs well so far.
I will stick with MPT from now.
Fande,
> On Mon, Jul 20, 2020 at 3:04 PM Chris Hewson <chris at resfrac.com> wrote:
>> Hi Mark,
>> Chris: It sounds like you just have one matrix that you give to MUMPS.
>> You seem to be creating a matrix in the middle of your run. Are you doing
>> dynamic adaptivity?
>> - I have 2 separate matrices I give to mumps, but as this is happening in
>> the production build of my code, I can't determine with certainty what call
>> to MUMPS it's happening or what call to KSPBCGS or UMFPACK it's happening
>> in.
>> I do destroy and recreate matrices in the middle of my runs, but this
>> happens multiple times before the fault happens and in (presumably) the
>> same way. I also do checks on matrix sizes and what I am sending to PETSc
>> and those all pass, just at some point there are size mismatches
>> somewhere, understandably this is not a lot to go on. I am not doing
>> dynamic adaptivity, the mesh is instead changing its size.
>> And I agree with Fande, the most frustrating part is that it's not
>> reproducible, but yah not 100% sure that the problem lies within the PETSc
>> code base either.
>> Current working theories are:
>> 1. Some sort of MPI problem with the sending of one the matrix elements
>> (using mpich version 3.3a2)
>> 2. Some of the memory of static pointers gets corrupted, although I would
>> expect a garbage number and not something that could possibly make sense.
>> *Chris Hewson*
>> Senior Reservoir Simulation Engineer
>> ResFrac
>> +1.587.575.9792
>> On Mon, Jul 20, 2020 at 12:41 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Mon, Jul 20, 2020 at 2:36 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> Hi Mark,
>>>> Just to be clear, I do not think it is related to GAMG or PtAP. It is a
>>>> communication issue:
>>> Youe stack trace was from PtAP, but Chris's problem is not.
>>>> Reran the same code, and I just got :
>>>> [252]PETSC ERROR: --------------------- Error Message
>>>> [252]PETSC ERROR: Petsc has generated inconsistent data
>>>> [252]PETSC ERROR: Received vector entry 4469094877509280860 out of
>>>> local range [255426072,256718616)]
>>> OK, now this (4469094877509280860) is clearly garbage. THat is the
>>> important thing. I have to think your MPI is buggy.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/eb758145/attachment.html>
