[petsc-users] Tough to reproduce petsctablefind error
Junchao Zhang
junchao.zhang at gmail.com
Mon Jul 20 15:30:11 CDT 2020
On Mon, Jul 20, 2020 at 2:26 PM Chris Hewson <chris at resfrac.com> wrote:
> Chris is using Haswell, what MPI are you using? I trust you are not using
> Moose.
> - yes, using haswell, mpi is mpich v3.3a2 on ubuntu 18.04. I am not using
> MOOSE.
Do not use mpich v3.3a2, which is an alpha version released in 2016. Use
current stable release mpich-3.3.2
> *Chris Hewson*
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
> On Mon, Jul 20, 2020 at 1:14 PM Mark Adams <mfadams at lbl.gov> wrote:
>> This is indeed a nasty bug, but having two separate should be useful.
>> Moose.
>> Fande what machine/MPI are you using?
>> On Mon, Jul 20, 2020 at 3:04 PM Chris Hewson <chris at resfrac.com> wrote:
>>> Hi Mark,
>>> Chris: It sounds like you just have one matrix that you give to MUMPS.
>>> You seem to be creating a matrix in the middle of your run. Are you doing
>>> dynamic adaptivity?
>>> - I have 2 separate matrices I give to mumps, but as this is happening
>>> in the production build of my code, I can't determine with certainty what
>>> call to MUMPS it's happening or what call to KSPBCGS or UMFPACK it's
>>> happening in.
>>> I do destroy and recreate matrices in the middle of my runs, but this
>>> happens multiple times before the fault happens and in (presumably) the
>>> same way. I also do checks on matrix sizes and what I am sending to PETSc
>>> and those all pass, just at some point there are size mismatches
>>> somewhere, understandably this is not a lot to go on. I am not doing
>>> dynamic adaptivity, the mesh is instead changing its size.
>>> And I agree with Fande, the most frustrating part is that it's not
>>> reproducible, but yah not 100% sure that the problem lies within the PETSc
>>> code base either.
>>> Current working theories are:
>>> 1. Some sort of MPI problem with the sending of one the matrix elements
>>> (using mpich version 3.3a2)
>>> 2. Some of the memory of static pointers gets corrupted, although I
>>> would expect a garbage number and not something that could possibly make
>>> sense.
>>> *Chris Hewson*
>>> ResFrac
>>> +1.587.575.9792
>>> On Mon, Jul 20, 2020 at 12:41 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> On Mon, Jul 20, 2020 at 2:36 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>> Hi Mark,
>>>>> Just to be clear, I do not think it is related to GAMG or PtAP. It is
>>>>> a communication issue:
>>>> Youe stack trace was from PtAP, but Chris's problem is not.
>>>>> Reran the same code, and I just got :
>>>>> [252]PETSC ERROR: --------------------- Error Message
>>>>> [252]PETSC ERROR: Petsc has generated inconsistent data
>>>>> [252]PETSC ERROR: Received vector entry 4469094877509280860 out of
>>>>> local range [255426072,256718616)]
>>>> OK, now this (4469094877509280860) is clearly garbage. THat is the
>>>> important thing. I have to think your MPI is buggy.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/2be31158/attachment.html>
