[petsc-users] Tough to reproduce petsctablefind error
Mark Adams
mfadams at lbl.gov
Mon Jul 20 14:14:26 CDT 2020
This is indeed a nasty bug, but having two separate should be useful.
Chris is using Haswell, what MPI are you using? I trust you are not using
Moose.
Fande what machine/MPI are you using?
On Mon, Jul 20, 2020 at 3:04 PM Chris Hewson <chris at resfrac.com> wrote:
> Hi Mark,
> Chris: It sounds like you just have one matrix that you give to MUMPS. You
> seem to be creating a matrix in the middle of your run. Are you doing
> dynamic adaptivity?
> - I have 2 separate matrices I give to mumps, but as this is happening in
> the production build of my code, I can't determine with certainty what call
> to MUMPS it's happening or what call to KSPBCGS or UMFPACK it's happening
> in.
> I do destroy and recreate matrices in the middle of my runs, but this
> happens multiple times before the fault happens and in (presumably) the
> same way. I also do checks on matrix sizes and what I am sending to PETSc
> and those all pass, just at some point there are size mismatches
> somewhere, understandably this is not a lot to go on. I am not doing
> dynamic adaptivity, the mesh is instead changing its size.
> And I agree with Fande, the most frustrating part is that it's not
> reproducible, but yah not 100% sure that the problem lies within the PETSc
> code base either.
> Current working theories are:
> 1. Some sort of MPI problem with the sending of one the matrix elements
> (using mpich version 3.3a2)
> 2. Some of the memory of static pointers gets corrupted, although I would
> expect a garbage number and not something that could possibly make sense.
> *Chris Hewson*
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
> On Mon, Jul 20, 2020 at 12:41 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Mon, Jul 20, 2020 at 2:36 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Hi Mark,
>>> Just to be clear, I do not think it is related to GAMG or PtAP. It is a
>>> communication issue:
>> Youe stack trace was from PtAP, but Chris's problem is not.
>>> Reran the same code, and I just got :
>>> [252]PETSC ERROR: --------------------- Error Message
>>> [252]PETSC ERROR: Petsc has generated inconsistent data
>>> [252]PETSC ERROR: Received vector entry 4469094877509280860 out of local
>>> range [255426072,256718616)]
>> OK, now this (4469094877509280860) is clearly garbage. THat is the
>> important thing. I have to think your MPI is buggy.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/54e334f7/attachment.html>
