[petsc-users] Errors encountered with KSPsolver with MATNEST and VECNEST
    Karl Yang
    y.juntao at hotmail.com
    Thu Jul 16 00:23:23 CDT 2020
Hi, Junchao,
Thank you. It works. :)
May I ask some follow up question regarding the same example about fieldsplit. I am trying to learn about matnest with fieldsplit preconditioner on manual page 94. But I get a bit lost trying to understand fields, ISs once it is not eactly the same on the manual.
In this same example, I tried to use PCFIELDSPLIT and PCFieldSplitSetDetectSaddlePoint as follows.
IS rows[3];
IS cols[3];
MatNestGetISs(testMesh->system, rows, cols);
KSP ksp;
PC pc;
KSPCreate(PETSC_COMM_WORLD, &ksp);
KSPSetType(ksp, KSPFGMRES);
KSPSetOperators(ksp, testMesh->system, testMesh->system);
KSPGetPC(ksp, &pc);
PCFieldSplitSetIS(pc, "u", rows[0]);
PCFieldSplitSetIS(pc, "v", rows[1]);
PCFieldSplitSetIS(pc, "p", rows[2]);
PCSetType(pc, PCFIELDSPLIT);
PCFieldSplitSetDetectSaddlePoint(pc, PETSC_TRUE);
KSPSetUp(ksp);
KSPSolve(ksp, testMesh->rhs, testMesh->solution);
But I will get the following error,
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Arguments are incompatible
[0]PETSC ERROR: Could not find index set
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
[0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by Unknown Thu Jul 16 13:08:39 2020
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
[0]PETSC ERROR: #1 MatNestFindIS() line 365 in /usr/local/petsc/petsc-3.12.5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: #2 MatNestFindSubMat() line 425 in /usr/local/petsc/petsc-3.12.5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: #3 MatCreateSubMatrix_Nest() line 456 in /usr/local/petsc/petsc-3.12.5/src/mat/impls/nest/matnest.c
[0]PETSC ERROR: #4 MatCreateSubMatrix() line 7859 in /usr/local/petsc/petsc-3.12.5/src/mat/interface/matrix.c
[0]PETSC ERROR: #5 PCSetUp_FieldSplit() line 676 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #6 PCSetUp() line 894 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #7 KSPSetUp() line 376 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: Corrupt argument: https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: Invalid Pointer to Object: Parameter # 1
[0]PETSC ERROR: #8 MatDestroy() line 1266 in /usr/local/petsc/petsc-3.12.5/src/mat/interface/matrix.c
[0]PETSC ERROR: #9 PCSetUp_FieldSplit() line 697 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #10 PCSetUp() line 894 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #11 KSPSetUp() line 376 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #12 KSPSolve() line 703 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
I read about the examples on the manual and mostly are based on 22 blocks but still cannot figure out how pcfieldsplit should be set in this 3 *3 blocks, and how IS should be set accordingly. I read about -fieldsplit_1_pc_type none option suggested on the documentation, but I am not sure is it still valid in a 33 blocks.
Regards
JT
On Jul 16 2020, at 6:57 am, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Adding the MatNestSetVecType() line fixed the problem. But I don't know why petsc had this weird design originally.
> MatCreateNest(PETSC_COMM_WORLD, 3, NULL, 3, NULL, mblock, &testMesh->system);
> + MatNestSetVecType(testMesh->system,VECNEST);
> --Junchao Zhang
> On Wed, Jul 15, 2020 at 2:16 PM Karl Yang <y.juntao at hotmail.com (mailto:y.juntao at hotmail.com)> wrote:
> > Hi, Barry,
> > I created a minimum example to reproduce the error. The example code is attached.
> > Mat Object: 1 MPI processes
> > type: nest
> > Matrix object:
> > type=nest, rows=3, cols=3
> > MatNest structure:
> > (0,0) : type=seqaij, rows=5, cols=5
> > (0,1) : NULL
> > (0,2) : type=seqaij, rows=5, cols=5
> > (1,0) : NULL
> > (1,1) : type=seqaij, rows=5, cols=5
> > (1,2) : type=seqaij, rows=5, cols=5
> > (2,0) : type=seqaij, rows=5, cols=5
> > (2,1) : type=seqaij, rows=5, cols=5
> > (2,2) : NULL
> > Vec Object: 1 MPI processes
> > type: nest
> > VecNest, rows=3, structure:
> > (0) : type=seq, rows=5
> > type: seq
> > 1.
> > 1.
> > 1.
> > 1.
> > 1.
> > (1) : type=seq, rows=5
> > type: seq
> > 1.
> > 1.
> > 1.
> > 1.
> > 1.
> > (2) : type=seq, rows=5
> > type: seq
> > 1.
> > 1.
> > 1.
> > 1.
> > 1.
> > [0]PETSC ERROR: Invalid argument
> > [0]PETSC ERROR: Nest vector argument 2 not setup.
> > [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by Unknown Thu Jul 16 03:11:02 2020
> > [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in /usr/local/petsc/petsc-3.12.5/src/vec/vec/impls/nest/vecnest.c
> > [0]PETSC ERROR: #2 VecCopy() line 1577 in /usr/local/petsc/petsc-3.12.5/src/vec/vec/interface/vector.c
> > [0]PETSC ERROR: #3 KSPInitialResidual() line 61 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itres.c
> > [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/gmres.c
> > [0]PETSC ERROR: #5 KSPSolve() line 760 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
> > On Jul 16 2020, at 2:39 am, Barry Smith <bsmith at petsc.dev (mailto:bsmith at petsc.dev)> wrote:
> > > Could be a bug in PETSc, please send a sample program that produces the problem.
> > > Barry
> > > > On Jul 15, 2020, at 1:28 PM, Karl Yang <y.juntao at hotmail.com (https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/0?redirect=mailto%3Ay.juntao%40hotmail.com&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > > > Hi, Barry,
> > > > Thanks for your reply. I output the matrix and vec with matview and vecview. And I think I do have the values set as it has been shown.
> > > > type: nest
> > > > Matrix object:
> > > > MatNest structure:
> > > > (0,0) : type=seqaij, rows=25, cols=25
> > > > (0,1) : NULL
> > > > (0,2) : type=seqaij, rows=25, cols=25
> > > > (1,0) : NULL
> > > > (1,1) : type=seqaij, rows=25, cols=25
> > > > (1,2) : type=seqaij, rows=25, cols=25
> > > > (2,0) : type=seqaij, rows=25, cols=25
> > > > (2,1) : type=seqaij, rows=25, cols=25
> > > > (2,2) : NULL
> > > > type: nest
> > > > (0) : type=seq, rows=25
> > > > type: seq
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 75.8279
> > > > -51.0776
> > > > -75.8279
> > > > 0.
> > > > 0.
> > > > -90.8404
> > > > 58.7011
> > > > 90.8404
> > > > 0.
> > > > 0.
> > > > -75.8279
> > > > 51.0776
> > > > 75.8279
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > (1) : name="Vec_0x84000000_0", type=seq, rows=25
> > > > Vec Object: Vec_0x84000000_0 1 MPI processes
> > > > type: seq
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 75.8279
> > > > -51.0776
> > > > -75.8279
> > > > 0.
> > > > 0.
> > > > -90.8404
> > > > 58.7011
> > > > 90.8404
> > > > 0.
> > > > 0.
> > > > -75.8279
> > > > 51.0776
> > > > 75.8279
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > (2) : type=seq, rows=25
> > > > type: seq
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > 0.
> > > > [0]PETSC ERROR: Nest vector argument 4 not setup.
> > > > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html (https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/1?redirect=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D) for trouble shooting.
> > > > [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by Unknown Thu Jul 16 02:15:26 2020
> > > > [0]PETSC ERROR: #1 VecPointwiseMult_Nest() line 245 in /usr/local/petsc/petsc-3.12.5/src/vec/vec/impls/nest/vecnest.c
> > > > [0]PETSC ERROR: #2 VecPointwiseMult() line 1107 in /usr/local/petsc/petsc-3.12.5/src/vec/vec/interface/vector.c
> > > > [0]PETSC ERROR: #3 PCApply_Jacobi() line 272 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/jacobi/jacobi.c
> > > > [0]PETSC ERROR: #4 PCApply() line 444 in /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
> > > > [0]PETSC ERROR: #5 KSP_PCApply() line 281 in /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
> > > > [0]PETSC ERROR: #6 KSPInitialResidual() line 65 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itres.c
> > > > [0]PETSC ERROR: #7 KSPSolve_GMRES() line 236 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/gmres.c
> > > > [0]PETSC ERROR: #8 KSPSolve() line 760 in /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
> > > > On Jul 16 2020, at 2:13 am, Barry Smith <bsmith at petsc.dev (https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/2?redirect=mailto%3Absmith%40petsc.dev&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > > > > From the error message the second vector you are using to form the nest vector has not been completely created/set up. Make sure you called either VecCreateSeq(), VecCreateMPI() or did VecCreate(), VecSetType(), VecSetUp() and if it is the right hand side make sure you put numerical values in it.
> > > > > Barry
> > > > > > On Jul 15, 2020, at 1:05 PM, Karl Yang <y.juntao at hotmail.com (https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/3?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F0%3Fredirect%3Dmailto%253Ay.juntao%2540hotmail.com%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D)> wrote:
> > > > > > Hello,
> > > > > > I'm trying to solve a 2*2 block matrix system.
> > > > > > I managed to form a 2*2 MatNest and a 21 VecNest. However when I try to make use of ksp solve, I encounter the following error. There is only one or two examples on MatNest and VecNest. I could not figure out what could be the trouble.
> > > > > > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html (https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/4?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F1%3Fredirect%3Dhttps%253A%252F%252Fwww.mcs.anl.gov%252Fpetsc%252Fdocumentation%252Ffaq.html%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D) for trouble shooting.
> > > > > > [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by Unknown Thu Jul 16 01:56:11 2020
> > > > > > Regards
> > > > > > JT
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200716/11e6cb12/attachment-0001.html>
