[petsc-users] Errors encountered with KSPsolver with MATNEST and VECNEST
Jed Brown
jed at jedbrown.org
Wed Jul 15 23:03:57 CDT 2020
It's a bit tedious to determine whether all vectors have the same type. The problem here is that this function assumes that y is of the same type as x.
static PetscErrorCode VecCopy_Nest(Vec x,Vec y)
Vec_Nest *bx = (Vec_Nest*)x->data;
Vec_Nest *by = (Vec_Nest*)y->data;
PetscInt i;
PetscErrorCode ierr;
PetscFunctionBegin;
VecNestCheckCompatible2(x,1,y,2);
for (i=0; i<bx->nb; i++) {
ierr = VecCopy(bx->v[i],by->v[i]);CHKERRQ(ierr);
PetscFunctionReturn(0);
IMO, a strong majority of MatNest users are better off using standard Vecs (not VecNest).
Junchao Zhang <junchao.zhang at gmail.com> writes:
> Adding the MatNestSetVecType() line fixed the problem. But I don't know
> why petsc had this weird design originally.
> MatCreateNest(PETSC_COMM_WORLD, 3, NULL, 3, NULL, mblock,
> &testMesh->system);
> + MatNestSetVecType(testMesh->system,VECNEST);
> --Junchao Zhang
> On Wed, Jul 15, 2020 at 2:16 PM Karl Yang <y.juntao at hotmail.com> wrote:
>> Hi, Barry,
>> I created a minimum example to reproduce the error. The example code is
>> attached.
>> Mat Object: 1 MPI processes
>> type: nest
>> Matrix object:
>> type=nest, rows=3, cols=3
>> MatNest structure:
>> (0,0) : type=seqaij, rows=5, cols=5
>> (0,1) : NULL
>> (0,2) : type=seqaij, rows=5, cols=5
>> (1,0) : NULL
>> (1,1) : type=seqaij, rows=5, cols=5
>> (1,2) : type=seqaij, rows=5, cols=5
>> (2,0) : type=seqaij, rows=5, cols=5
>> (2,1) : type=seqaij, rows=5, cols=5
>> (2,2) : NULL
>> Vec Object: 1 MPI processes
>> type: nest
>> VecNest, rows=3, structure:
>> (0) : type=seq, rows=5
>> type: seq
>> 1.
>> 1.
>> 1.
>> 1.
>> 1.
>> (1) : type=seq, rows=5
>> type: seq
>> 1.
>> 1.
>> 1.
>> 1.
>> 1.
>> (2) : type=seq, rows=5
>> type: seq
>> 1.
>> 1.
>> 1.
>> 1.
>> 1.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Nest vector argument 2 not setup.
>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
>> [0]PETSC ERROR: ./testSolve on a arch-linux2-c-debug named f601294ac804 by
>> Unknown Thu Jul 16 03:11:02 2020
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --download-mpich --download-fblaslapack --with-cuda
>> [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
>> /usr/local/petsc/petsc-3.12.5/src/vec/vec/impls/nest/vecnest.c
>> [0]PETSC ERROR: #2 VecCopy() line 1577 in
>> /usr/local/petsc/petsc-3.12.5/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: #3 KSPInitialResidual() line 61 in
>> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itres.c
>> [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
>> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: #5 KSPSolve() line 760 in
>> /usr/local/petsc/petsc-3.12.5/src/ksp/ksp/interface/itfunc.c
>> On Jul 16 2020, at 2:39 am, Barry Smith <bsmith at petsc.dev> wrote:
>> Could be a bug in PETSc, please send a sample program that produces the
>> problem.
>> Barry
>> On Jul 15, 2020, at 1:28 PM, Karl Yang <y.juntao at hotmail.com
>> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/0?redirect=mailto%3Ay.juntao%40hotmail.com&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
>> wrote:
>> Hi, Barry,
>> Thanks for your reply. I output the matrix and vec with matview and
>> vecview. And I think I do have the values set as it has been shown.
>> type: nest
>> Matrix object:
>> MatNest structure:
>> (0,0) : type=seqaij, rows=25, cols=25
>> (0,1) : NULL
>> (0,2) : type=seqaij, rows=25, cols=25
>> (1,0) : NULL
>> (1,1) : type=seqaij, rows=25, cols=25
>> (1,2) : type=seqaij, rows=25, cols=25
>> (2,0) : type=seqaij, rows=25, cols=25
>> (2,1) : type=seqaij, rows=25, cols=25
>> (2,2) : NULL
>> type: nest
>> (0) : type=seq, rows=25
>> type: seq
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 75.8279
>> -51.0776
>> -75.8279
>> 0.
>> 0.
>> -90.8404
>> 58.7011
>> 90.8404
>> 0.
>> 0.
>> -75.8279
>> 51.0776
>> 75.8279
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> (1) : name="Vec_0x84000000_0", type=seq, rows=25
>> Vec Object: Vec_0x84000000_0 1 MPI processes
>> type: seq
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 75.8279
>> -51.0776
>> -75.8279
>> 0.
>> 0.
>> -90.8404
>> 58.7011
>> 90.8404
>> 0.
>> 0.
>> -75.8279
>> 51.0776
>> 75.8279
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> (2) : type=seq, rows=25
>> type: seq
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> 0.
>> [0]PETSC ERROR: Nest vector argument 4 not setup.
>> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/1?redirect=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D> for
>> trouble shooting.
>> Unknown Thu Jul 16 02:15:26 2020
>> [0]PETSC ERROR: #1 VecPointwiseMult_Nest() line 245 in
>> [0]PETSC ERROR: #2 VecPointwiseMult() line 1107 in
>> [0]PETSC ERROR: #3 PCApply_Jacobi() line 272 in
>> /usr/local/petsc/petsc-3.12.5/src/ksp/pc/impls/jacobi/jacobi.c
>> [0]PETSC ERROR: #4 PCApply() line 444 in
>> /usr/local/petsc/petsc-3.12.5/src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: #5 KSP_PCApply() line 281 in
>> /usr/local/petsc/petsc-3.12.5/include/petsc/private/kspimpl.h
>> [0]PETSC ERROR: #6 KSPInitialResidual() line 65 in
>> [0]PETSC ERROR: #7 KSPSolve_GMRES() line 236 in
>> [0]PETSC ERROR: #8 KSPSolve() line 760 in
>> On Jul 16 2020, at 2:13 am, Barry Smith <bsmith at petsc.dev
>> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/2?redirect=mailto%3Absmith%40petsc.dev&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
>> wrote:
>> From the error message the second vector you are using to form the nest
>> vector has not been completely created/set up. Make sure you called either
>> VecCreateSeq(), VecCreateMPI() or did VecCreate(), VecSetType(), VecSetUp()
>> and if it is the right hand side make sure you put numerical values in it.
>> Barry
>> On Jul 15, 2020, at 1:05 PM, Karl Yang <y.juntao at hotmail.com
>> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/3?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F0%3Fredirect%3Dmailto%253Ay.juntao%2540hotmail.com%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D>>
>> wrote:
>> Hello,
>> I'm trying to solve a 2*2 block matrix system.
>> I managed to form a 2*2 MatNest and a 21 VecNest. However when I try to
>> make use of ksp solve, I encounter the following error. There is only one
>> or two examples on MatNest and VecNest. I could not figure out what could
>> be the trouble.
>> <https://link.getmailspring.com/link/060AB2C3-F3D7-408C-99CF-C4D1B27DD59F@getmailspring.com/4?redirect=https%3A%2F%2Flink.getmailspring.com%2Flink%2F540F752A-DB59-4878-9C98-B8F4B4D9FD0D%40getmailspring.com%2F1%3Fredirect%3Dhttps%253A%252F%252Fwww.mcs.anl.gov%252Fpetsc%252Fdocumentation%252Ffaq.html%26recipient%3DYnNtaXRoQHBldHNjLmRldg%253D%253D&recipient=cGV0c2MtdXNlcnNAbWNzLmFubC5nb3Y%3D> for
>> trouble shooting.
>> Unknown Thu Jul 16 01:56:11 2020
>> Regards
>> JT
>> [image: Sent from Mailspring]
