[petsc-users] VecAssemblyEnd_MPI_BTS
Barry Smith
bsmith at petsc.dev
Tue Jul 14 16:09:48 CDT 2020
valgrind?
> On Jul 14, 2020, at 11:29 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> The petsc configuration log was attached.
> Thanks,
> Fande,
> On Tue, Jul 14, 2020 at 9:16 AM Fande Kong <fdkong.jd at gmail.com <mailto:fdkong.jd at gmail.com>> wrote:
> Hi All,
> I was doing a large-scale simulation using 12288 cores and had the following error. The code ran fine using less than 12288 cores.
> Any quick suggestions to track down this issue?
> Thanks,
> Fande,
> [3342]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [3342]PETSC ERROR: Petsc has generated inconsistent data
> [3342]PETSC ERROR: Received vector entry 0 out of local range [344829312,344964096)]
> [3342]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [3342]PETSC ERROR: Petsc Release Version 3.13.3, unknown
> [3342]PETSC ERROR: /home/kongf/workhome/sawtooth/griffin/griffin-opt on a arch-moose named r1i4n34 by kongf Tue Jul 14 08:44:02 2020
> [3342]PETSC ERROR: Configure options --download-hypre=1 --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1 --download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1 --download-slepc=1 --with-mpi=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices --download-mumps=0
> [3342]PETSC ERROR: #1 VecAssemblyEnd_MPI_BTS() line 324 in /home/kongf/workhome/sawtooth/moosers/petsc/src/vec/vec/impls/mpi/pbvec.c
> [3342]PETSC ERROR: #2 VecAssemblyEnd() line 171 in /home/kongf/workhome/sawtooth/moosers/petsc/src/vec/vec/interface/vector.c
> [cli_3342]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 3342
> <configure.log.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200714/0bd76f30/attachment.html>
