[petsc-users] VecAssemblyEnd_MPI_BTS
Jed Brown jed at jedbrown.org
Tue Jul 14 15:41:46 CDT 2020
Is it possible to run this with a different MPI?  Zero is suspicious in that perhaps the message wasn't delivered, rather than that it was delivered with incorrect data.  This sounds like a tough one if it isn't reproducible (preferably at smaller scale).
Fande Kong <fdkong.jd at gmail.com> writes:
> The petsc configuration log was attached.
> Thanks,
> Fande,
> On Tue, Jul 14, 2020 at 9:16 AM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Hi All,
>> I was doing a large-scale simulation using 12288 cores and had the
>> following error. The code ran fine using less than 12288 cores.
>> Any quick suggestions to track down this issue?
>> Thanks,
>> Fande,
>> [3342]PETSC ERROR: --------------------- Error Message
>> [3342]PETSC ERROR: Petsc has generated inconsistent data
>> [3342]PETSC ERROR: Received vector entry 0 out of local range
>> [344829312,344964096)]
>> [3342]PETSC ERROR: See
>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [3342]PETSC ERROR: Petsc Release Version 3.13.3, unknown
>> [3342]PETSC ERROR: /home/kongf/workhome/sawtooth/griffin/griffin-opt on a
>> arch-moose named r1i4n34 by kongf Tue Jul 14 08:44:02 2020
>> [3342]PETSC ERROR: Configure options --download-hypre=1
>> --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1
>> --download-metis=1 --download-ptscotch=1 --download-parmetis=1
>> --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1
>> --download-slepc=1 --with-mpi=1 --with-cxx-dialect=C++11
>> --with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices
>> --download-mumps=0
>> [3342]PETSC ERROR: #1 VecAssemblyEnd_MPI_BTS() line 324 in
>> /home/kongf/workhome/sawtooth/moosers/petsc/src/vec/vec/impls/mpi/pbvec.c
>> [3342]PETSC ERROR: #2 VecAssemblyEnd() line 171 in
>> /home/kongf/workhome/sawtooth/moosers/petsc/src/vec/vec/interface/vector.c
>> [cli_3342]: aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 3342
