[petsc-users] use superlu and hypre's gpu features through PETSc
Mark Adams mfadams at lbl.gov
Fri Jan 17 07:37:47 CST 2020
Stafano ported hypre to SUMMIT to use CUDA in
branch stefanozampini/hypre-cuda-rebased
Fragile and performance was poor.
On Thu, Jan 16, 2020 at 9:44 PM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>    That is superlu_dist and hypre.
>    Yes, but both backends are rather primitive and will be a little
> struggle to use.
>    For superlu_dist you need to get the branch
> barry/fix-superlu_dist-py-for-gpus and rebase it against master
>    I only recommend trying them if you are adventuresome. Note that
> PETSc's GAMG can also utilize the GPU.
>    Barry
> > On Jan 16, 2020, at 4:31 PM, Xiangdong <epscodes at gmail.com> wrote:
> > Dear Developers,
> > From the online documentation, both superlu and hypre have some gpu
> functionalities. Can we use these gpu features through PETSc's interface?
> > Thank you.
> > Best,
> > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200117/83dff824/attachment.html>
