[petsc-users] use superlu and hypre's gpu features through PETSc
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Jan 16 20:44:29 CST 2020
That is superlu_dist and hypre.
Yes, but both backends are rather primitive and will be a little struggle to use.
For superlu_dist you need to get the branch barry/fix-superlu_dist-py-for-gpus and rebase it against master
I only recommend trying them if you are adventuresome. Note that PETSc's GAMG can also utilize the GPU.
Barry
> On Jan 16, 2020, at 4:31 PM, Xiangdong <epscodes at gmail.com> wrote:
> Dear Developers,
> From the online documentation, both superlu and hypre have some gpu functionalities. Can we use these gpu features through PETSc's interface?
> Thank you.
> Best,
> Xiangdong
