[petsc-users] Solver compilation with 64-bit version of PETSc under Windows 10 using Cygwin
Balay, Satish balay at mcs.anl.gov
Wed Jan 15 13:15:17 CST 2020
On Wed, 15 Jan 2020, Matthew Knepley wrote:
> On Wed, Jan 15, 2020 at 10:26 AM Дмитрий Мельничук <
> dmitry.melnichuk at geosteertech.com> wrote:
> > > And I'm not sure why you are having to use PetscInt for ierr. All PETSc
> > routines should be suing 'PetscErrorCode for ierr'
> > If I define *ierr *as *PetscErrorCode *for all subroutines given below
> > call VecDuplicate(Vec_U,Vec_Um,ierr)
> > call VecCopy(Vec_U,Vec_Um,ierr)
> > call VecGetLocalSize(Vec_U,j,ierr)
> > call VecGetOwnershipRange(Vec_U,j1,j2,ierr)
> > then errors occur with first three subroutines:
> > *Error: Type mismatch in argument «z» at (1); passed INTEGER(4) to
> > INTEGER(8).*
> Barry,
> It looks like the ftn-auto interfaces are using 'integer' for the error
> code, whereas the ftn-custom is using PetscErrorCode.
> Could we make the generated ones use integer?
Well it needs a fix to bfort. But then there are a bunch of other issues wrt MPI - its not clear [to me] how to fix [wrt -fdefault-integer-8]
Satish
>   Thanks,
>      Matt
> > Therefore I was forced to define *ierr *as *PetscInt *for VecDuplicate,
> > VecCopy, VecGetLocalSize subroutines to fix these errors.
> > Why some subroutines sue 8-bytes integer type of *ierr *(*PetscInt*),
> > while others - 4-bytes integer type of *ierr *(*PetscErrorCode*) remains
> > a mystery for me.
> > > What version of PETSc are you using?
> > version 3.12.2
> > > Are you seeing this issue with a PETSc example?
> > I will check it tomorrow  and let you know.
> > Kind regards,
> > Dmitry Melnichuk
> > 15.01.2020, 17:14, "Balay, Satish" <balay at mcs.anl.gov>:
> > -fdefault-integer-8 is likely to break things [esp with MPI - where
> > 'integer' is used everywhere for ex - MPI_Comm etc - so MPI includes become
> > incompatible with the MPI library with -fdefault-integer-8.]
> > What version of PETSc are you using? Are you seeing this issue with a
> > PETSc example?
> > Satish
> > On Wed, 15 Jan 2020, Дмитрий Мельничук wrote:
> >  Hello all!
> >   At present time I need to compile solver called Defmod (
> > https://bitbucket.org/stali/defmod/wiki/Home), which is written in
> > Fortran 95.
> >  Defmod uses PETSc for solving linear algebra system.
> >  Solver compilation with 32-bit version of PETSc does not cause any
> > problem.
> >  But solver compilation with 64-bit version of PETSc produces an error
> > with size of ierr PETSc variable.
> >  1. For example, consider the following statements written in Fortran:
> >  PetscErrorCode :: ierr_m
> >  PetscInt :: ierr
> >  call VecGetOwnershipRange(Vec_U,j1,j2,ierr_m)
> >  As can be seen first three subroutunes require ierr to be size
> > of INTEGER(8), while the last subroutine (VecGetOwnershipRange)
> > requires ierr to be size of INTEGER(4).
> >  Using the same integer format gives an error:
> >  There is no specific subroutine for the generic ‘vecgetownershiprange’ at
> > (1)
> >  2. Another example is:
> >  call MatAssemblyBegin(Mat_K,Mat_Final_Assembly,ierr)
> >  CHKERRA(ierr)
> >  call MatAssemblyEnd(Mat_K,Mat_Final_Assembly,ierr)
> >  I am not able to define an appropriate size if ierr in CHKERRA(ierr). If
> > I choose INTEGER(8), the error "Type mismatch in argument ‘ierr’ at (1);
> > passed INTEGER(8) to
> >  INTEGER(4)" occurs.
> >  If I define ierr  as INTEGER(4), the error "Type mismatch in argument
> > ‘ierr’ at (1); passed INTEGER(4) to INTEGER(8)" appears.
> >  3. If I change the sizes of ierr vaiables as error messages require, the
> > compilation completed successfully, but an error occurs when calculating
> > the RHS vector with
> >  following message:
> >  [0]PETSC ERROR: Out of range index value -4 cannot be negative
> >  Command to configure 32-bit version of PETSc under Windows 10 using
> > Cygwin:
> >  ./configure --with-cc=x86_64-w64-mingw32-gcc
> > --with-cxx=x86_64-w64-mingw32-g++ --with-fc=x86_64-w64-mingw32-gfortran
> > --download-fblaslapack
> >  --with-mpi-include=/cygdrive/c/MPISDK/Include
> > --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a
> > --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes
> >  -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static
> > -lpthread -fno-range-check' --with-shared-libraries=no
> >   Command to configure 64-bit version of PETSc under Windows 10 using
> > Cygwin:./configure --with-cc=x86_64-w64-mingw32-gcc
> >  --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack
> >  -fdefault-integer-8' --with-shared-libraries=no --with-64-bit-indices
> > --known-64-bit-blas-indices
> >  Kind regards,
> >  Dmitry Melnichuk
