[petsc-users] Solver compilation with 64-bit version of PETSc under Windows 10 using Cygwin
Wed Jan 15 11:55:22 CST 2020
On Wed, Jan 15, 2020 at 10:26 AM Дмитрий Мельничук <
dmitry.melnichuk at geosteertech.com> wrote:
> > And I'm not sure why you are having to use PetscInt for ierr. All PETSc
> routines should be suing 'PetscErrorCode for ierr'
> If I define *ierr *as *PetscErrorCode *for all subroutines given below
> call VecDuplicate(Vec_U,Vec_Um,ierr)
> call VecCopy(Vec_U,Vec_Um,ierr)
> call VecGetLocalSize(Vec_U,j,ierr)
> call VecGetOwnershipRange(Vec_U,j1,j2,ierr)
> then errors occur with first three subroutines:
> *Error: Type mismatch in argument «z» at (1); passed INTEGER(4) to
> INTEGER(8).*
Barry,
It looks like the ftn-auto interfaces are using 'integer' for the error
code, whereas the ftn-custom is using PetscErrorCode.
Could we make the generated ones use integer?
     Matt
> Therefore I was forced to define *ierr *as *PetscInt *for VecDuplicate,
> VecCopy, VecGetLocalSize subroutines to fix these errors.
> Why some subroutines sue 8-bytes integer type of *ierr *(*PetscInt*),
> while others - 4-bytes integer type of *ierr *(*PetscErrorCode*) remains
> a mystery for me.
> > What version of PETSc are you using?
> version 3.12.2
> > Are you seeing this issue with a PETSc example?
> I will check it tomorrow  and let you know.
> Kind regards,
> Dmitry Melnichuk
> 15.01.2020, 17:14, "Balay, Satish" <balay at mcs.anl.gov>:
> -fdefault-integer-8 is likely to break things [esp with MPI - where
> 'integer' is used everywhere for ex - MPI_Comm etc - so MPI includes become
> incompatible with the MPI library with -fdefault-integer-8.]
> What version of PETSc are you using? Are you seeing this issue with a
> PETSc example?
> Satish
> On Wed, 15 Jan 2020, Дмитрий Мельничук wrote:
>  Hello all!
>   At present time I need to compile solver called Defmod (
> https://bitbucket.org/stali/defmod/wiki/Home), which is written in
> Fortran 95.
>  Defmod uses PETSc for solving linear algebra system.
>  Solver compilation with 32-bit version of PETSc does not cause any
> problem.
>  But solver compilation with 64-bit version of PETSc produces an error
> with size of ierr PETSc variable.
>  1. For example, consider the following statements written in Fortran:
>  PetscErrorCode :: ierr_m
>  PetscInt :: ierr
>  call VecGetOwnershipRange(Vec_U,j1,j2,ierr_m)
>  As can be seen first three subroutunes require ierr to be size
> of INTEGER(8), while the last subroutine (VecGetOwnershipRange)
> requires ierr to be size of INTEGER(4).
>  Using the same integer format gives an error:
>  There is no specific subroutine for the generic ‘vecgetownershiprange’ at
> (1)
>  2. Another example is:
>  call MatAssemblyBegin(Mat_K,Mat_Final_Assembly,ierr)
>  CHKERRA(ierr)
>  call MatAssemblyEnd(Mat_K,Mat_Final_Assembly,ierr)
>  I am not able to define an appropriate size if ierr in CHKERRA(ierr). If
> I choose INTEGER(8), the error "Type mismatch in argument ‘ierr’ at (1);
> passed INTEGER(8) to
>  INTEGER(4)" occurs.
>  If I define ierr  as INTEGER(4), the error "Type mismatch in argument
> ‘ierr’ at (1); passed INTEGER(4) to INTEGER(8)" appears.
>  3. If I change the sizes of ierr vaiables as error messages require, the
> compilation completed successfully, but an error occurs when calculating
> the RHS vector with
>  following message:
>  [0]PETSC ERROR: Out of range index value -4 cannot be negative
>  Command to configure 32-bit version of PETSc under Windows 10 using
> Cygwin:
>  ./configure --with-cc=x86_64-w64-mingw32-gcc
> --with-cxx=x86_64-w64-mingw32-g++ --with-fc=x86_64-w64-mingw32-gfortran
> --download-fblaslapack
>  --with-mpi-include=/cygdrive/c/MPISDK/Include
> --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a
> --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes
>  -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static
> -lpthread -fno-range-check' --with-shared-libraries=no
>   Command to configure 64-bit version of PETSc under Windows 10 using
> Cygwin:./configure --with-cc=x86_64-w64-mingw32-gcc
>  --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack
>  -fdefault-integer-8' --with-shared-libraries=no --with-64-bit-indices
> --known-64-bit-blas-indices
>  Kind regards,
>  Dmitry Melnichuk
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200115/a1901619/attachment-0001.html>
