[petsc-users] Using DMDAs with an assigned domain decomposition to Solve Poisson Equation
Mark Adams mfadams at lbl.gov
Mon Feb 24 07:20:38 CST 2020
> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex14f.F90.html
> Thanks, i will try to give a look to this example and i will try to check
> also C examples in that directory.
There are a lot of places with examples (this is actually not an
obvious place). The web page for each method lists examples that use it and
similar methods. You can find examples by following these links too.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200224/7dba20d2/attachment.html>
