[petsc-users] Using DMDAs with an assigned domain decomposition to Solve Poisson Equation
Mon Feb 24 05:24:24 CST 2020
On Mon, Feb 24, 2020 at 5:30 AM Pierpaolo Minelli <pierpaolo.minelli at cnr.it>
wrote:
> Hi,
> I'm developing a 3D code in Fortran to study the space-time evolution of
> charged particles within a Cartesian domain.
> The domain decomposition has been made by me taking into account symmetry
> and load balancing reasons related to my specific problem.
That may be a problem. DMDA can only decompose itself along straight lines
through the domain. Is that how your decomposition looks?
> In this first draft, it will remain constant throughout my simulation.
> Is there a way, using DMDAs, to solve Poisson's equation, using the domain
> decomposition above, obtaining as a result the local solution including its
> ghost cells values?
How do you discretize the Poisson equation?
    Matt
> As input data at each time-step I know the electric charge density in each
> local subdomain (RHS), including the ghost cells, even if I don't think
> they are useful for the calculation of the equation.
> Matrix coefficients (LHS) and boundary conditions are constant during my
> simulation.
> As an output I would need to know the local electrical potential in each
> local subdomain, including the values of the ghost cells in each
> dimension(X,Y,Z).
> Is there an example that I can use in Fortran to solve this kind of
> problem?
> Thanks in advance
> Pierpaolo Minelli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200224/a0447eb9/attachment.html>
