[petsc-users] Using PETSc with GPU supported SuperLU_Dist
Satish Balay
balay at mcs.anl.gov
Sat Feb 22 20:59:14 CST 2020
The fix is now in both maint and master
https://gitlab.com/petsc/petsc/-/merge_requests/2555
Satish
On Sat, 22 Feb 2020, Junchao Zhang via petsc-users wrote:
> We met the error before and knew why. Will fix it soon.
> --Junchao Zhang
> On Sat, Feb 22, 2020 at 11:43 AM Abhyankar, Shrirang G via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Thanks, Satish. Configure and make go through fine. Getting an undefined
> > reference error for VecGetArrayWrite_SeqCUDA.
> > Shri
> > *From: *Satish Balay <balay at mcs.anl.gov>
> > *Reply-To: *petsc-users <petsc-users at mcs.anl.gov>
> > *Date: *Saturday, February 22, 2020 at 8:25 AM
> > *To: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
> > *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> > *Subject: *Re: [petsc-users] Using PETSc with GPU supported SuperLU_Dist
> > On Sat, 22 Feb 2020, Abhyankar, Shrirang G via petsc-users wrote:
> > Hi,
> > I want to install PETSc with GPU supported SuperLU_Dist. What are the
> > configure options I should be using?
> > Shri,
> > if self.framework.argDB['download-superlu_dist-gpu']:
> > self.cuda = framework.require('config.packages.cuda',self)
> > self.openmp =
> > framework.require('config.packages.openmp',self)
> > self.deps =
> > [self.mpi,self.blasLapack,self.cuda,self.openmp]
> > So try:
> > --with-cuda=1 --download-superlu_dist=1 --download-superlu_dist-gpu=1
> > --with-openmp=1 [and usual MPI, blaslapack]
> > Satish
