[petsc-users] Using PETSc with GPU supported SuperLU_Dist
Junchao Zhang jczhang at mcs.anl.gov
Sat Feb 22 20:53:46 CST 2020
We met the error before and knew why. Will fix it soon.
--Junchao Zhang
On Sat, Feb 22, 2020 at 11:43 AM Abhyankar, Shrirang G via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thanks, Satish. Configure and make go through fine. Getting an undefined
> reference error for VecGetArrayWrite_SeqCUDA.
> Shri
> *From: *Satish Balay <balay at mcs.anl.gov>
> *Reply-To: *petsc-users <petsc-users at mcs.anl.gov>
> *Date: *Saturday, February 22, 2020 at 8:25 AM
> *To: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Using PETSc with GPU supported SuperLU_Dist
> On Sat, 22 Feb 2020, Abhyankar, Shrirang G via petsc-users wrote:
> Hi,
>     I want to install PETSc with GPU supported SuperLU_Dist. What are the
> configure options I should be using?
> Shri,
>     if self.framework.argDB['download-superlu_dist-gpu']:
>       self.cuda           = framework.require('config.packages.cuda',self)
>       self.openmp         =
> framework.require('config.packages.openmp',self)
>       self.deps           =
> [self.mpi,self.blasLapack,self.cuda,self.openmp]
> So try:
> --with-cuda=1 --download-superlu_dist=1 --download-superlu_dist-gpu=1
> --with-openmp=1 [and usual MPI, blaslapack]
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200222/045cf7cc/attachment.html>
