[petsc-users] [petsc-maint] "make ... all" failure
Jin Chen jchen at pppl.gov
Fri Feb 21 13:20:22 CST 2020
errors from setting   --with-64-bit-indices=0 :
/opt/pgi/19.5/linux86-64-llvm/19.5/include/edg/xmmintrin.h(2514): internal
error: assertion failed at:
"/dvs/p4/build/sw/rel/gpu_drv/r440/TC440_70/drivers/compiler/edg/EDG_5.0/src/sys_predef.c",
line 574
1 catastrophic error detected in the compilation of
"/tmp/tmpxft_00004945_00000000-4_aijcusparse.cpp4.ii".
Compilation aborted.
nvcc error   : 'cudafe++' died due to signal 6
gmake[2]: ***
[tigergpu-pgi195-openmpi/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o]
Error 6
On Fri, Feb 21, 2020 at 2:09 PM Mark Adams <mfadams at lbl.gov> wrote:
> Please send the error that you see with --with-64-bit-indices=0. This
> should not be hard to fix.
> And yes, always start with a clean environment when you get a strange
> error. Compile time errors are very rare.
> On Fri, Feb 21, 2020 at 1:26 PM Jin Chen <jchen at pppl.gov> wrote:
>> I tried and found
>> --with-64-bit-indices=1
>> works.
>> But mumps and superlu don't have 64-bit support.
>> -- Jin
>> On Fri, Feb 21, 2020 at 12:07 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Cool, a compiler error.
>>> First, delete the "arch" directory and configure again. This a deep
>>> 'make clean'. Something you need to do this when you switch branches.
>>> On Fri, Feb 21, 2020 at 11:30 AM Jin Chen via petsc-maint <
>>> petsc-maint at mcs.anl.gov> wrote:
>>>> Hi,
>>>> I'm installing petsc branch
>>>> barry/fix-superlu_dist-py-for-gpus
>>>> on another computer for testing. It passed configure, but failed at
>>>> "make .... all".
>>>> Would you please take a look? Both configure.log and make.log are
>>>> attached.
>>>> Thanks,
>>>> -- Jin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200221/b3a92421/attachment.html>
