[petsc-users] [petsc-maint] "make ... all" failure
Mark Adams
mfadams at lbl.gov
Fri Feb 21 13:09:17 CST 2020
Please send the error that you see with --with-64-bit-indices=0. This
should not be hard to fix.
And yes, always start with a clean environment when you get a strange
error. Compile time errors are very rare.
On Fri, Feb 21, 2020 at 1:26 PM Jin Chen <jchen at pppl.gov> wrote:
> I tried and found
> --with-64-bit-indices=1
> works.
> But mumps and superlu don't have 64-bit support.
> -- Jin
> On Fri, Feb 21, 2020 at 12:07 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Cool, a compiler error.
>> First, delete the "arch" directory and configure again. This a deep 'make
>> clean'. Something you need to do this when you switch branches.
>> On Fri, Feb 21, 2020 at 11:30 AM Jin Chen via petsc-maint <
>> petsc-maint at mcs.anl.gov> wrote:
>>> Hi,
>>> I'm installing petsc branch
>>> barry/fix-superlu_dist-py-for-gpus
>>> on another computer for testing. It passed configure, but failed at
>>> "make .... all".
>>> Would you please take a look? Both configure.log and make.log are
>>> attached.
>>> Thanks,
>>> -- Jin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200221/6934895d/attachment.html>
